After using it for years I now get message on screen "Windows Vista Build 6002 This copy of Windows is not genuine "
2011-05-29T10:36:13+00:00
After using Windows Vista for years in my Dell Inspiron1420 laptop  I now get message on screen
I am then told
This copy of Windows is not activated.Click here to activate Windows now
Product ID  89578-OEM-7332157-00204   Change Product Key
when I do that I am told it is INVALID
Dell confirm they do not preload fake windows software.
What can I do?
Windows for home | Previous Windows versions | Install and upgrade
    2011-05-30T14:08:21+00:00
    How do I do that pse?
    Thanks for thye substantive reply
    2011-05-30T14:29:37+00:00
    Edit your Key out? - hit the Edit button on your post and delete the Key, then hit the Submit button.
    2011-05-30T15:50:40+00:00
    Noel,
    I found the Edit key but decided to delete the whole e-mail to be sure, as I didn't think there was anything that would help anybody. Your replies are the most important part of the exchange.
    I started to follow your instructions but found a confusing selection of CMD files and none which was precisely CMD.exe. There were:
    cmd    - windows command processor 60.6001.18000
    cmdkey - credental manager command live utility
    cmdl32  - microsoft connectionmanager autodownload 7.2.6001.18000
    cmdkey.exe.mui
    cmd.exe.mui
    cmd132.exe.mui
    I don't want to press the wrong one and screw  up the computer so which one must I click??
    Sorry to be such a bore
    Ceci
    2011-05-30T17:08:06+00:00
    Just use CMD
    2011-05-30T18:28:16+00:00
    Noel: I seem to be getting nowhere fast!
    I reached step 5 OK and received the following message"The following services are dependent on the Software Licensing Service. Stopping the software Licensing Service will also stop these services:SLUI Notification Service & Ready Boost - Do you want to continue (Y/N) I entered Y and was informed that The SLUI Notification Service service was stopped successfully.
    I then entered step 6 and pressed the enter key to continue and was told
    file name, directory name or volume label syntax is incorrect
    and was  returned to the beginning ie C:\Windows\system32>
    Where am I going wrong?
    I am assuming that after following instructions 6,7, 8,9 and 10 I should press the enter key before moving on to the next instruction
