Lifecam Studio stopped working after firmware upgrade?!?
2011-02-22T07:17:34+00:00
Hi All.
I bought a new LifecamStudio 2 days ago. I installed the camera, following the instructions of course. In the end of the installation, I could se my self in the Lifecam software window, so far no problems, the camera worked. Suddenly a popup message appeared, telling me that the firmware of the camera needed to be upgraded, so I pressed OK. The firmware upgrade started but was shortly aborted with an errormessage, saying the upgrade was not succesfull. I tryed to reinstall  the firmware, but now it tells me hat I already have the most recent firmware installed. So the nproblem is now that, when I instert my camera into the USB port windows finds the camera, but as soon as I start any program the uses the camera it goes from a Lifecam Icon (in the hardware manager that is) to a unknown unit. The Lifecam studio software tells me that no camera is installed. I have installed the camera on other computers without any luck.
/Stefan
2011-04-11T21:46:02+00:00
Fixed it :)
In device manager underneath imaging devices I saw "Webcam" -- before the botched fw update it said "Microsoft LifeCam Studio" and had a diff driver.  I rolled back the driver (or if that doesn't work you can force it to use the one inside program files \ lifecam) then re-installed lifecam -- my cam now works.  Now -- what's the deal with this update utility and why's it changing what driver the camera uses?
67 additional answers
    2011-05-18T02:32:08+00:00
    Lifecam worked perfectly for 3 hours. Then, up pops the message "firmware upgrade needed" and then, it has not worked since. Fortunately, I can return it since it is only 1 day old. I will try a second camera, NOT do the faulty, bricky firmware update and see if it works. If not, return and done with it. It is clear that there is a problem and simply asking everyone to reinstall the drivers is ridiculous. BTW, I did, and it made no difference. Please, please, please Microsoft, don't give the Apple world more fodder.
    2011-05-18T02:43:29+00:00
    I don't understand why rolling back the driver worked for me and no one else...
    Also fyi -- never update the firmware of ANY usb device if it's going through a hub (even a powered hub)....always direct connect it.
    2011-06-01T20:43:13+00:00
    I have had the same problem since upgrading the firmware on a new LifeCam Studio.
    It is not a driver problem for me.  I have a second Studio camera here that did not get the faulty firmware upgrade, and all the software and drivers work perfectly with it.
    There is clearly a problem with the firmware upgrade software, but no one appears to be acknowledging it.
    2011-06-13T22:04:47+00:00
    I have the same problem here. Can anybody instruct us how to roll back a firmware? Can you post the working firmare somehow?
    Thanks for help. Any thoughts would be much appreciated!
