Hello all,
For those of you posting about your LifeCam failing after applying a firmware update, let me apologize for the experience. This firmware update may have failed if the LifeCam was attached to the PC through a USB Hub device when
the firmware update was attempted. If this was the cause for your issue, you would have seen the following message when installing the update:
“The update failed. DO NOT unplug your webcam. Verify that your webcam’s USB plug is firmly seated in the USB port on your computer, and try again.”
For customers that have a LifeCam that no longer works after a firmware update, we ask that you contact the Microsoft Supplemental Parts team at the contact numbers below:
United States: (800) 360-7561, Monday through Friday, 5:00 A.M. to 7:00 P.M. Pacific Time.
Canada: (800) 933-4750, Monday through Friday, 5:00 A.M. to 7:00 P.M. Pacific Time.
TTY customers: Contact Microsoft at (800) 718-1599, Monday through Friday, 5:00 A.M. to 7:00 P.M. Pacific Time.
If you are outside the US or Canada please visit http://www.microsoft.com/hardware/en-us/support/contact-us
to find contact numbers in your region.
