"Allow a device to connect" is greyed out, bluetooth
2011-10-26T15:52:46+00:00
I am unable to connect any device to the laptop through bluetooth, even though I've used the feature before.
When I switch the bluetooth on and right click on the bluetooth icon - "Allow a device to connect" is greyed out.".
I'm using Windows 7, 64 bit. Any suggestions...?
2014-11-21T22:55:10+00:00
HOW TO PAIR/CONNECT A BLUETOOTH SPEAKER TO LAPTOP/PC/WINDOWS 7 SOLVED....
Bought a Bletooth speaker ages ago, it is good for what it is and managed to get it paired up with all my other devices - tablet, phone but have never been able to connect it to my Sony Vaio laptop - would always pair then never be able to connect it. Here's how I got it to work..
I decided to start afresh and delete all Bluetooth devices and start again.
Make sure you have your computer Bluetooth turned on
Down in the bottom right tool bar right click on the Bluetooth icon
Click on Join a Personal Area Network
Opens a new Window in Devices and printers
Turn on your Bluetooth Speaker to discover mode
Click Add a Device
Your speaker should show up
DO NOT CLICK NEXT.....
INSTEAD A MESSAGE SHOULD POP UP FROM THE TOOLBAR SAYING A DEVICE IS ASKING TO CONNECT
CLICK THIS MESSAGE
it will then ask you to add a pairing number to connect ( add the default number if your speaker has one refer to manual)
In this case the XMI X-Mini WE does not come with one so I put in 0000
Worked!!
Paired
Now click on Start - Devices and Printers and you should see the speaker XMI X-Mini WE
Right click it and click control
Click connect......
BOOM paired and working
Dont know how or why its working but I an now listening to music via my Bluetooth Speaker.
Now I now this may not work for all but This was driving me nuts and hope it at least works for some..
73 additional answers
    2012-04-19T02:06:10+00:00
    I am having the reverse issue. My mobile finds my computer but my computer does not find my mobile and the "allow a device to connect" is grayed out even after restarting and uninstalling and reinstalling my driver. I am also on win 7 64bit.
    I have no clue how to make my computer find my phone or allow it to connect. Although my phone finds my computer, when it tries to pair, it says "match passkeys on computer?" and gives me a passkey between 4-6 digits, (different every time) attempts to pair, and finally says it is "unable to pair with computer".  Any ideas on how to make my computer find my phone or allow it to connect?
    2012-04-21T00:27:41+00:00
    Hi Everyone,
    Im having the same problem... first it was bluetooth peripheral device did not install correctly or could not be found but now by devices are just greyed out (such as my bluetooth mouse) and my samsung galaxy can no longer connect, it just says that it has taken too long for the device to connect. (and yes the device is visible!) Before that i was able to pair them and they were recognising each other but i wasnt able to send files either way and the laptop would just say copying then discovering services available and then no services available.
    It is very frustrating!! I am also running on Windows 7 64-bit.
    Help!
    2012-05-15T05:54:16+00:00
    Has anyone solved this.  Exact same situations.  Working one day...not working the next.  I even bought a new mouse and have the same problem.
    2012-08-22T01:50:02+00:00
    Same problem here using Windows 8 and 64 bit ASUS Zenbook.  Cannot connect to simple bluetooth speaker.
