"Allow a device to connect" is greyed out, bluetooth
2011-10-26T15:52:46+00:00
I am unable to connect any device to the laptop through bluetooth, even though I've used the feature before.
When I switch the bluetooth on and right click on the bluetooth icon - "Allow a device to connect" is greyed out.".
I'm using Windows 7, 64 bit. Any suggestions...?
2014-11-21T22:55:10+00:00
HOW TO PAIR/CONNECT A BLUETOOTH SPEAKER TO LAPTOP/PC/WINDOWS 7 SOLVED....
Bought a Bletooth speaker ages ago, it is good for what it is and managed to get it paired up with all my other devices - tablet, phone but have never been able to connect it to my Sony Vaio laptop - would always pair then never be able to connect it. Here's how I got it to work..
I decided to start afresh and delete all Bluetooth devices and start again.
Make sure you have your computer Bluetooth turned on
Down in the bottom right tool bar right click on the Bluetooth icon
Click on Join a Personal Area Network
Opens a new Window in Devices and printers
Turn on your Bluetooth Speaker to discover mode
Click Add a Device
Your speaker should show up
DO NOT CLICK NEXT.....
INSTEAD A MESSAGE SHOULD POP UP FROM THE TOOLBAR SAYING A DEVICE IS ASKING TO CONNECT
CLICK THIS MESSAGE
it will then ask you to add a pairing number to connect ( add the default number if your speaker has one refer to manual)
In this case the XMI X-Mini WE does not come with one so I put in 0000
Worked!!
Paired
Now click on Start - Devices and Printers and you should see the speaker XMI X-Mini WE
Right click it and click control
Click connect......
BOOM paired and working
Dont know how or why its working but I an now listening to music via my Bluetooth Speaker.
Now I now this may not work for all but This was driving me nuts and hope it at least works for some..
73 additional answers
    2016-07-13T23:34:35+00:00
    The problem is that it is Windows 10. I got my phone's Bluetooth to work on my Windows 7 computer. As far as I know, the problem is entirely Windows 10. Solution: Uninstall Windows 10 and use a different operating system.
    2016-07-14T11:12:22+00:00
    If you have any feedback related to Windows and want some changes in the next version or update then you need to post them on the Feedback app. For providing your findings, issue, bugs and comments on the feedback app you may refer to the steps provided below.
    • Press the Windows key.
    • Type Feedback in the box.
    • Click on Windows Feedback (Trusted Windows Store app).
    • Then follow the on screen instruction to provide feedback.
    Hope the information provided is helpful. Do let us know if you have any queries related to Windows, we will be happy to assist you.
    Regards,
    2016-11-23T00:45:16+00:00
    I use windows 8.0 on my laptop but i still cant conect any device
    2017-01-19T17:07:44+00:00
    Unfortunately, this has not helped with my Bluetooth problem.
    I have an EasyAcc speaker, which used to work but now doesn't, and a wireless mouse which I bought new and which has never worked. Any other advice please.
