"Allow a device to connect" is greyed out, bluetooth
2011-10-26T15:52:46+00:00
I am unable to connect any device to the laptop through bluetooth, even though I've used the feature before.
When I switch the bluetooth on and right click on the bluetooth icon - "Allow a device to connect" is greyed out.".
I'm using Windows 7, 64 bit. Any suggestions...?
2014-11-21T22:55:10+00:00
HOW TO PAIR/CONNECT A BLUETOOTH SPEAKER TO LAPTOP/PC/WINDOWS 7 SOLVED....
Bought a Bletooth speaker ages ago, it is good for what it is and managed to get it paired up with all my other devices - tablet, phone but have never been able to connect it to my Sony Vaio laptop - would always pair then never be able to connect it. Here's how I got it to work..
I decided to start afresh and delete all Bluetooth devices and start again.
Make sure you have your computer Bluetooth turned on
Down in the bottom right tool bar right click on the Bluetooth icon
Click on Join a Personal Area Network
Opens a new Window in Devices and printers
Turn on your Bluetooth Speaker to discover mode
Click Add a Device
Your speaker should show up
DO NOT CLICK NEXT.....
INSTEAD A MESSAGE SHOULD POP UP FROM THE TOOLBAR SAYING A DEVICE IS ASKING TO CONNECT
CLICK THIS MESSAGE
it will then ask you to add a pairing number to connect ( add the default number if your speaker has one refer to manual)
In this case the XMI X-Mini WE does not come with one so I put in 0000
Worked!!
Paired
Now click on Start - Devices and Printers and you should see the speaker XMI X-Mini WE
Right click it and click control
Click connect......
BOOM paired and working
Dont know how or why its working but I an now listening to music via my Bluetooth Speaker.
Now I now this may not work for all but This was driving me nuts and hope it at least works for some..
73 additional answers
    2014-12-20T00:47:14+00:00
    I've tried everything on this post.  None of them worked.  I can find the devices. Once I even got a code to connect (when trying to connect my iPhone 5). Even when I used it. It would not connect.  I could never get any code prompts with the Sony speakers.
    II can add both the sony device and my iphon on windows. But it won't connect. There isn't even any option to connect. It is grayed out.  Also I have to manually choose to use the generic driver listed in this post to even get anywhere.  But it still does not work.  Windows can not find a driver for either device.
    Super frustrating. I just wanted to listen to music from my laptop on my nice fancy Sony speakers.  (Which work perfect with my iPhone btw).
    I don't have the space on m desk to have the speakers. Otherwise I would use an aux cable and not deal with this mess.
    2014-12-21T10:08:04+00:00
    Welcome to Microsoft Community forum.
    I would suggest you to follow the steps provided below and update us on the status of the issue.
    Method 1: Run the fix-it suggested below and check.
    Bluetooth devices do not work correctly on a computer that is running Windows 7:
    **http://support.microsoft.com/kb/980396**
    If the above method does not work, go to next method.
    Method 2: Refer to the following suggestions.
    If computer doesn't recognize the Bluetooth enabled device then please try the below mentioned steps and see if it helps.
    · Remove and then reinstall the device:
    a. Click the Start button, click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
    b. Select the device that's not working, and then click Remove.
    c. Click Add, press the reset button on the device (or make it discoverable following the manufacturer's instructions), select the My device is set up and ready to be found check box, and then click Next.
    d. If the device is not found, repeat the previous step. When the device is found, select it, and then click Next.
    e. Follow the rest of the instructions in the wizard.
    · Make sure the device is turned on and that the batteries don't need to be replaced.
    · Make sure the Bluetooth adapter for your computer is attached and turned on, and that the device is turned on and discoverable. If you're not sure how to turn on discoverability, read the instructions that came with the device or check the manufacturer's website.
    · Make sure that you installed the device using the correct program. If not, reinstall the device.
    Refer the following links for more information:
    Add a Bluetooth enabled device to your computer ******http://windows.microsoft.com/en-US/windows7/Add-a-Bluetooth-enabled-device-to-your-computer**
    Connect to Bluetooth and other wireless or network devices ******http://windows.microsoft.com/en-US/windows7/Connect-to-Bluetooth-and-other-wireless-or-network-devices**
    Change settings for a Bluetooth enabled device ******http://windows.microsoft.com/en-US/windows7/Change-settings-for-a-Bluetooth-enabled-device**
    Do keep us updated about the issue and we will be happy to assist you.
    Regards.
    2015-03-02T14:19:50+00:00
    SIR,
        i have the problem that "allow a device to connect" is greyed out.... in dell inspiron 15z  wats wrong.... help me out
    2015-03-10T11:15:27+00:00
    Welcome to Microsoft Community forum and sorry for delayed response.
    There might be a chance that Bluetooth service might be missing so, try to check that service. Make sure the Bluetooth services are running on the computer. To start the Bluetooth services follow the steps below:
    1. Click on Start
    2. In the search box type run.
    3. Type Services.msc in run box and press enter.
    4. In the list find Bluetooth support services and double click on that.
    5. Ensure that the service is both set to automatic and started.
    Do keep us updated about the status of your issue and we will be happy to assist you.
    Regards,
