"Allow a device to connect" is greyed out, bluetooth
2011-10-26T15:52:46+00:00
I am unable to connect any device to the laptop through bluetooth, even though I've used the feature before.
When I switch the bluetooth on and right click on the bluetooth icon - "Allow a device to connect" is greyed out.".
I'm using Windows 7, 64 bit. Any suggestions...?
2014-11-21T22:55:10+00:00
HOW TO PAIR/CONNECT A BLUETOOTH SPEAKER TO LAPTOP/PC/WINDOWS 7 SOLVED....
Bought a Bletooth speaker ages ago, it is good for what it is and managed to get it paired up with all my other devices - tablet, phone but have never been able to connect it to my Sony Vaio laptop - would always pair then never be able to connect it. Here's how I got it to work..
I decided to start afresh and delete all Bluetooth devices and start again.
Make sure you have your computer Bluetooth turned on
Down in the bottom right tool bar right click on the Bluetooth icon
Click on Join a Personal Area Network
Opens a new Window in Devices and printers
Turn on your Bluetooth Speaker to discover mode
Click Add a Device
Your speaker should show up
DO NOT CLICK NEXT.....
INSTEAD A MESSAGE SHOULD POP UP FROM THE TOOLBAR SAYING A DEVICE IS ASKING TO CONNECT
CLICK THIS MESSAGE
it will then ask you to add a pairing number to connect ( add the default number if your speaker has one refer to manual)
In this case the XMI X-Mini WE does not come with one so I put in 0000
Worked!!
Paired
Now click on Start - Devices and Printers and you should see the speaker XMI X-Mini WE
Right click it and click control
Click connect......
BOOM paired and working
Dont know how or why its working but I an now listening to music via my Bluetooth Speaker.
Now I now this may not work for all but This was driving me nuts and hope it at least works for some..
73 additional answers
    2014-12-01T11:04:44+00:00
    Welcome to Microsoft Community forum.
    I want to know the troubleshooting steps which you have already tried?
    For now please try to check if the Bluetooth service and Bluetooth Supportare running and set to automatic or not and steps to check that are provided below.
    1. Press Windows Key + R, type **services.msc** and press Enter.
    2. Search for **Bluetooth support** service and **Bluetooth Support.**
    3. Check if it is started, if not **Right click** on the service and click on
    Start.
    If issue persist try to Run the hardware and device troubleshooter.
    **http://windows.microsoft.com/en-US/windows7/Open-the-Hardware-and-Devices-troubleshooter**
    Do keep us updated about the issue.
    2014-12-06T05:17:08+00:00
    It worked!!!! Thank you so so much!
    2014-12-09T10:25:34+00:00
    Hi Kathleen,
    Thank you for sharing your experience and update of your issue on. It is good to hear that your issue is resolved. We really appreciate your efforts and time which you spent on resolving the issue. This information will benefit other community members to solve their similar issues.
    In addition to that, you are always welcome to post your queries on Microsoft Community forum. We'll be glad to assist you again.
    Thank you.
    2014-12-19T16:04:37+00:00
    Kathleen ... what exactly worked for you?
    Mr. Kumar, I tried your previous method of running Troubleshoots and I found it really useful, however it DOES NOT resolve the issue of taking off the graying out of Bluetooth's function of "Allow a Device to Connect".
    To be specific, when I run the Troubleshoot for Sound Devices it now gives me the message that "hardware changes might not have been detected".  My specific question is how do I get my computer to recognize hardware changes?
