How to change monitor assignment in a dual monitor environment
2011-02-12T01:26:15+00:00
I have two monitors attached to my Windows 7 computer - a viewsonic monitor and an panasonic plasma tv.
Before I installed the tv - my Viewsonic sonic was the primary monitor. However, for some unknown reason - when I connected my Panasonic plasma tv to my video card - Windows made the TV as the number 1 primary monitor and my viewsonic as the secondary number 2 monitor.
How can I get Windows 7 to reverse those assignments? I want my Viewsonic monitor as the primary, number one monitor.
2011-02-17T18:49:52+00:00
When you rt click the desktop and select Screen Resolution, you will be presented with a window showing the two monitors, simply click/hold one of the montors shown and drag it to the required position.
There are also other options, eg Identify, and Display, use the drop down to select the display (monitor) to use as the 'main' display (Some options only impact if you are using Extended Display and not Duplicate display
44 additional answers
    2017-02-04T02:33:17+00:00
    No one seems to get it. The problem ...is not being able to CHANGE THE MONITOR NUMBERS....period. Windows 7 obviously has a fault that you CAN NOT change the numbers that Windows automatically assigns to the monitors/displays in a multi display setup. The "change display settings on multiple monitors" article, while good willed, is useless in regards to this problem. Microsoft needs to put out a fix for this that allows users to assign the monitor numbers themselves as there are many situations where this is critical to applications and programs to function correctly. I am having a MAJOR problem on our dual monitor systems at work because of this bug. COME ON MICROSOFT....GET ON IT ALREADY. This in not a new problem.
    I have multiple apps which require the monitors to be "flipped." Wouldn't it be easy to add a parameter in the "Details" Section of Properties, such as "UsrAssignedMonID" ?
    Agree, get on with it.
    2017-02-05T23:23:59+00:00
    Try This
    1. Turn off your secondary display
    2. Go to display settings, there probably will be only one display left - your monitor, and it will be marked as 1
    3. Restart your pc
    4. After logging back in go display settings, make sure settings are same as in step 2
    5. Connect your secondary display
    2017-02-05T23:32:02+00:00
    Been there, tried that, didn't work.
    Try This
    3. Restart your pc
    2017-02-06T12:59:06+00:00
    Sorry, but this procedure has been tried (and it fails) by thousands of people over the past many years.
    Upon execution of the step 5, Windows instantly changes the monitor #1 designation back to where it was originally.
