How to reconnect to a already paired bluetooth A2DP headset?
2009-12-03T13:50:48+00:00
I use a bluetooth stereo headset with my Laptop running Windows7/Fedora 12 and also with my mobile phone and with my ipod. I want to connect my headset to one of above devices at a time.
I have paired my headset with all of above devices (Windows 7, Fedora 12, my mobile and my ipod). Suppose I've currently connected my headset to the ipod and now I want to use it with my mobile. All I have to do is disconnect headset from ipod and connect it to my mobile. (The 'connect' and 'disconnect' facilities are there in both my ipod and mobile).
Suppose now I want to use the headset with Windows 7. (it's already paired and shown under Bluetooth Devices). Surprisingly in windows 7 there's no way of connecting to a already paired headset. (when you right-click on the headset icon under bluetooth devices there's no 'connect' options.). Now one might ask why don't you restart the headset? But it'll never work since headset will try to connect to the last device it connected. (in this case my mobile phone). Only way I can connect my headset to Windows 7 now is putting the headset back into pairing mode, deleting the headset from windows, and re pair it. This will take a lotof time and this will also install drivers for four bluetooth profiles headset supports. (A2DP, AVRCP, handsfree, headset). (This will also create a system restore point to make things slower).
Similar to my mobile phone and ipod in Fedora linux it's just a matter of right clicking bluetooth icon and selecting 'connect'. I have not used windows for a long time and may be I miss something very obvious or the way Windows 7 bluetooth works is very frustrating.
I use Windows 7 professional in a Dell Inspiron laptop. The bluetooth stack used is the one supplied with Wndows 7.
2010-07-20T14:39:16+00:00
Hi Jeff,
Reconnecting using Playback Devices works for reconnecting an already paired A2DP Bluetooth Headset to your PC, per the OP. Headsets are usually "dumb" in the respect that you cannot ask them to connect to a specific device, they just try to reconnect to the last device they connected to. Using "Playback Devices" gets around this by getting your computer to ping the device and ask it for a connection.
It sounds like you're having a totally different issue to the OP, namely that you can't get your android phone to connect to your PC after you've paired it. It's probably worth starting a new thread on that issue as it is completely separate to reconnecting "dumb" devices.
Apologies if I've misunderstood you.
67 additional answers
  1. Deleted
    2012-10-30T20:11:36+00:00
    Did you even read the question? He wants to reconnect an already working device. If the drivers need to be updated after that thats fine, but it should be done in the background after connecting the device.
    All other applications seem to have a 1 click reconnect except windows 7... a very important feature missing in my opinion.
    2012-11-06T12:11:46+00:00
    On my Win7 box, "Sound Settings" is a shortcut to Sound Devices dialog, which you can also get to by right-clicking the volume icon in your system tray and choosing 'Playback Devices'.
    However, I have now written a program to automate those steps to a single-click - download it here:
    http://zornsoftware.talsit.info/blog/bluetooth-service-connector.html
    Hopefully Microsoft is working on their bluetooth stack for Windows 8...
    lol, no.
    Same problem with Motorola S305 BT headset on ASUS G73S, Win8 Pro 64-bit.
    Have changed Bluetooth service to auto start as suggested in another thread, no change.
    Shows up in Devices, but is offline. Can only remove the device from here, no other options (right click, double click does nothing).
    Shows up in Control Panel/Devices and Printers, I can access it's properties, says it's working ok.
     - trouble shooting from here finds nothing wrong.
     - Under Events tag, says Device is installed (bth.inf)
    Shows up in Device Manager/Bluetooth - "This device is working properly".
     - Other bluetooth items are said to be working properly too.
    Doesn't show up in Device manager/Audio inputs and outputs.
    Doesn't show up in "sound" settings
    Doesn't show up in Volume mixer under Device.
    And of course, doesn't work.
    2012-12-14T17:06:51+00:00
    Why do you guys always provide useless information.  The problem issue is that device WAS paired using the latest drivers.  If you pair it to ANYTHING else after using Windows and powering down your PC/Laptop, for some reason Windows makes you go through the same pairing procedure again.  Nothing is being updated, Microsoft's software just can't seem to do the same thing it just did not long before.  The issue is NOT the drivers as they are still the same ones.  The issue is Microsoft's software.
         Microsoft is doing the "selfish friend" scenario, basically.  In other words, saying "Okay, I know you and we paired up before, but because you hung out with someone else, well now you have to jump through hoops to hang out with me again."
    "Either get on the ball or get off the field"
