Sorry for not getting back to this thread at the time. In the case of the laptop I was having trouble with, the hard drive had to be replaced. I don't know whether the HD was the cause of the original problem, or shutting down the Startup Repair process damaged the HD.
Startup Repair -- how long is too long?
I'm trying Startup Repair on a Windows Vista laptop that won't start up after having reportedly been shut down normally, after what sounded like a Trojan attack. (Not sure what happened to it exactly, but my friend wasn't running antivirus software!)
Startup Repair says "Repairing disk errors. This might take over an hour to complete," but it's been running for about 9 hours now, and trying to Cancel it yields the message "The current repair operation cannot be cancelled" -- is it still actually doing anything? Would it be worth it to let Startup Repair run any longer?
42 additional answers
2015-08-18T09:22:54+00:00 Startup Repair says "Repairing disk errors. This might take over an hour to complete," but it's been running for about 9 hours now, and trying to Cancel it yields the message "The current repair operation cannot be cancelled" -- is it still actually doing anything? Would it be worth it to let Startup Repair run any longer?
I have left this running for something like 16 hours now and just seemingly stuck at the same point. Will let it run, amazed to read it can take over three days. Would be nice to have some idea of progress...
I have the original OEM install disc so I guess I should be able to get it all back (eventually).
2015-08-24T16:43:42+00:00 400$?! I usually take 100€ for a complete check and reinstall.
2015-08-26T14:39:28+00:00 And finally, it turns out that THE REAL PROBLEM was that the hard drive was failing. It finally failed completely on August 8, 2015.
2015-08-26T15:55:52+00:00 Startup Repair says "Repairing disk errors. This might take over an hour to complete," but it's been running for about 9 hours now, and trying to Cancel it yields the message "The current repair operation cannot be cancelled" -- is it still actually doing anything? Would it be worth it to let Startup Repair run any longer?
In the end I stopped it by restarting the PC. Copied off all the files via Ubuntu (how glad am I making it dual boot) and did a custom install overwriting everything. Had a couple of failures due to missing drivers, but eventually Windows 7 reinstalled. Added all the updates to obtain Get Windows 10 and most importantly installed Ubuntu on a new partition. Installed all drivers for printer and wifi card. Then I did chkdsk and got no errors whatsoever. So now I just have to copy back all the data.
Two lessons learned.
First, back up your data in the cloud or an external drive. Leave a 64Gb Memory card in if need be and schedule saves.
Second, make every pc dual boot. At least that way there is a way in to copy things out if you haven't backed up.
luckily I did have dual boot and now so has every other pc in the house.
