How to Troubleshoot Bluetooth devices!
2009-08-07T02:06:02+00:00
I just bought a new laptop that supports Bluetooth and when try to connect my Bluetooth phone, mouse and headphones things just don’t work. I’m not making any progress. I’m having trouble getting these set up and working properly. Can someone point me to some general Bluetooth troubleshooting information that might help?
2009-08-07T02:07:42+00:00
Basic troubleshooting usually starts the same as with any other type of hardware devices. Try the following:
·         Make sure that the devices are supported by your operating system and then
·         Go to the manufacturer’s web site and download the latest version of software or drivers for those devices. While you’re there you might browse the site to see if there are known issues or other information for your device.
·         Make sure the Bluetooth device is listed in the Bluetooth Devices Browser in the Control Panel (keep in mind that some Bluetooth devices may install a custom dialog window for their device in the control panel).
·         Make sure that you’re system is up to date on any service packs and other updates for your operating system
For additional troubleshooting, browse to the topics listed below for other scenarios that you may run into.
You can also search the forums or even the manufacturer’s web sites for help for other issues with specific Bluetooth devices.
Troubleshoot problems with Bluetooth enabled devices
http://windowshelp.microsoft.com/Windows/en-US/Hel p/11a74104-645d-40d4-b933-bde5d15537bb1033.mspx
Set up a Bluetooth enabled device
http://windowshelp.microsoft.com/Windows/en-US/Help/67cdb8d4-c3fe-43db-a00e-53159bf8695b1033.mspx
What is a Bluetooth personal area network (PAN)?
http://windowshelp.microsoft.com/Windows/en-US/Help/c4d99703-d2da-4132-acda-7d23815609531033.mspx
911894 You receive an error message immediately after you install the USB transceiver for a Microsoft keyboard or optical mouse to configure Bluetooth on a Windows XP SP2-based computer
960531 The Bluetooth item in Control Panel on a Windows Vista SP2-based computer does not work as expected when you click the item
Connect to a Bluetooth personal area network (PAN)
http://windowshelp.microsoft.com/Windows/en-US/Help/703a6d0e-62dc-4382-a6b8-fc247a7964831033.mspx
58 additional answers
    2009-12-22T03:16:16+00:00
    To ensure your computer had install the driver. And had you active the bluetooth function?
    Fix Windows 7 slow || Faster windows 7
    2010-01-31T00:22:21+00:00
    I have had the same problem and found that the hot sync gets stuck at date book.  Once stuck you have to reboot to access the com. I was able to get the hot sync to work partially stopping each time at date book. I pretty much gave up as I know my HP BT500 works fine and I have installed and reinstalled according to blogs the latest Palm Desktop. Windows 7 is a problem. This worked fine on my Vista laptop.
    2010-02-04T15:14:52+00:00
    Ive got the MS Wireless Entertainment Keyboard 8000 withWireless Laser Mouse 8000
    Running Vista on a Fujitsu PC, mouse was a bit erratic, so I used a usb mouse. I upgraded to Windows 7 - the mouse was then PERFECT. After a couple of updates from MS, the mouse is now erratic again. As far as I know I'm up to date with all required updates and drivers.
    I have a couple of questions:
    1. in Devices screen, Ive got TWO keyboards listed - 'Microsoft Wireless Entertainment Keyboard 8000' and just plain 'Wireless Entertainment Keyboard 8000' - should I have that?
    2. there are 4 mice listed in teh Device Manager - 2 wireless and 2 HID compliant - should i delete the extras and if so.... how can i tell which is which?
    3. in the HID section there are 2xbluetooth; 14xHID compliant consumer control device, 2 x HID compliant device and 2 x xUSB input device - all for one KB and one mouse...?
    4. my keyboard is listed as HID Keyboard device in device manager (one usb one bluetooth.)
    anyone at MS got any insight into the poor mouse performance? its like its low on power or miles from the bluetooth transciever. It isnt on both cases.
    thanks
    2010-03-30T05:42:35+00:00
    I'm having a similar problem with a Microsoft Bluetooth Notebook Mouse 5000.  I set the mouse to 'discoverable', Windows finds the mouse, lists it in the find new hardware screen, I click it, it installs, the icon appears in my hardware list for ~10 seconds and then disappears. The mouse never actually works. It never gives an error message, it just spontaneously forgets the mouse immediately after installation. I have installed the Bluetooth hardware drivers from the laptop manufacturer, and Microsoft does not have specialized drivers for this mouse (it just uses the standard Bluetooth HID mouse drivers)
    I happen to know the mouse works and the Bluetooth hardware on this Laptop works mainly because this in a MacBook Pro and the mouse works fine in Mac OS X (of course). Lol, so my Microsoft mouse doesn't work with Microsoft Windows 7 but it does work with Mac OS X, ain't that a kick in the head.
    The reply by Bobby Mikkelson did not solve my problem. Windows 7 finds it OK but it wont keep it connected.
    Also, this problem is new (for me) for Windows 7, I used Windows XP previously on this machine and the mouse worked fine.
    I recently purchased an ASUS N61J Series with WIndows 7. I have been having some major issues with my bluetooth capability. SPecifically the same things that Leopard has. Has anyone found a way to fix this? I have tried uninstalling the software and reinstalling it. I have tried rolling back windows to a previous setting. The best that I have been able to do is to either Reinstall windows from the hidden drive and start back to normal or use an external Bluetooth Dongel. IF I use the dongel, then I cannot use any of the special features associated with the Mouse.
    Any help telling me where to go or whta to do would be great. I reinstalled windows several weeks ago and everything was fine until the last couple of days when things started acting weird again.
