How to Troubleshoot Bluetooth devices!
2009-08-07T02:06:02+00:00
I just bought a new laptop that supports Bluetooth and when try to connect my Bluetooth phone, mouse and headphones things just don’t work. I’m not making any progress. I’m having trouble getting these set up and working properly. Can someone point me to some general Bluetooth troubleshooting information that might help?
2009-08-07T02:07:42+00:00
Basic troubleshooting usually starts the same as with any other type of hardware devices. Try the following:
·         Make sure that the devices are supported by your operating system and then
·         Go to the manufacturer’s web site and download the latest version of software or drivers for those devices. While you’re there you might browse the site to see if there are known issues or other information for your device.
·         Make sure the Bluetooth device is listed in the Bluetooth Devices Browser in the Control Panel (keep in mind that some Bluetooth devices may install a custom dialog window for their device in the control panel).
·         Make sure that you’re system is up to date on any service packs and other updates for your operating system
For additional troubleshooting, browse to the topics listed below for other scenarios that you may run into.
You can also search the forums or even the manufacturer’s web sites for help for other issues with specific Bluetooth devices.
Troubleshoot problems with Bluetooth enabled devices
http://windowshelp.microsoft.com/Windows/en-US/Hel p/11a74104-645d-40d4-b933-bde5d15537bb1033.mspx
Set up a Bluetooth enabled device
http://windowshelp.microsoft.com/Windows/en-US/Help/67cdb8d4-c3fe-43db-a00e-53159bf8695b1033.mspx
What is a Bluetooth personal area network (PAN)?
http://windowshelp.microsoft.com/Windows/en-US/Help/c4d99703-d2da-4132-acda-7d23815609531033.mspx
911894 You receive an error message immediately after you install the USB transceiver for a Microsoft keyboard or optical mouse to configure Bluetooth on a Windows XP SP2-based computer
960531 The Bluetooth item in Control Panel on a Windows Vista SP2-based computer does not work as expected when you click the item
Connect to a Bluetooth personal area network (PAN)
http://windowshelp.microsoft.com/Windows/en-US/Help/703a6d0e-62dc-4382-a6b8-fc247a7964831033.mspx
58 additional answers
    2010-10-16T16:35:45+00:00
    Same thing is happening with my PS3
    2010-11-07T17:06:16+00:00
    I have the same problem with my JAbra Halo headset, Win7 64.
    The only way to get it to connect is to re-pair the device. After the first pairing it connects, but after that it won't connect anymore. I actually exchanged my Halo thinking it was it's fault, but today I got my replacement unit and the same thing happens.
    I have uninstalled and reinstalled the drivers countless times.  And, this happened at my previous Win 7 32 bit OS as well.
    I must say, I am tired of the "solutions" such as "make sure the devices are turned on etc"  anyone smart enough to create a MS LIve username and find a forum and post a question, is WAY past that point.
    I think every discussion needs to be accompanied by the stack that is used, and the drivers that are used. Assuming you are using the microsoft stack and the csr headset drivers, I experience exactly the same problem, but only on the stereo a2dp profile. They suck. I might depend on the firmware 4.4839 lmp version. It's in rom. I know the toshiba stack works fine on an it.
    What worse, nobody supports this stuff. Microsoft refers to the device/headset manufacturers. CSR refers to their customers. Headset makers refer to the dongle/radio makers. The dongle makers ship one of many stacks.
    In the end, nobody is supporting the csr drivers for the microsoft stack.
    IT'S A BIG MESS
  3. Deleted
    2010-11-22T19:03:51+00:00
    And you lot think you have problems???
     I have just spent EIGHT hours on the phone with microsoft support and they have been totally unable to get by bluetooth devices working again. I have only just upgrade to 7 from vista and they all worked great before the upgrade. Now nothing works at all and those so called experts at microsoft can't find any way to help. I feel that these probllems should be explained to customers BEFORE we pay out our hard earned dosh on these,what can best be descibed as sub-standard product.
    I have given up and will re-install vista as it was perfectly acceptable and only upgraded on advice from microsoft tech guys.  ( maybe they are on commission ??)
