Its working!!!!!!!!
Phoned Accu-Chek and told them my problems and they said someone from there IT department would phone me back.....and they did! Thats a miracle to start with, a company phoning you back when you have a problem, for me its a first anyway!
Then he seemed to know straight away and i qoute "Have you got the Icons on your desktop enlarged?"
I wasnt sure as i hadnt altered them since i first installed w8 over a year ago, and yes i had, as soon as i set them back to 100% and loged back in the app ran perfectly. I say perfectly but what i mean is it ran perfectly in a dsandboxed version of windows
7 32bit running in VMware Player ( thank you LewisMacKenzie :) ) as the MS Server 2012 will not uninstall no matter what i do, yes i tried to uninstal via programs, it says its "not installed", yes i tried uninstalling by running setup from the dvd "server IS installed", i even removed folders and
went through the registry removing any reference to sql but still its there, or rather not there but is sort of lol.......But thats a MS screw up not Accu-Cheks,just thought i would post my solution.
- make sure resolution is above 1024 x 768.
- THIS INCLUDES having your Icons set at 100% magnification, nothing above, or, magnified!
- Install everything as Admin.
- Install MS Server once dont install it and then mess something up or you will not be able to install again it seems!
- Works in a sandbox VMware running Windows 7 32bit as a virtual OS.....Dont know about anything else as i dont posess any other OS apart from that and W8.1 64bit (but w8.1 dosent play fairly if it sees any other OS so i am not attempting to install w8.1
as a virtual OS on a w8.1 system so dont ask me too!!! Been there in the past wish i hadnt believe me!!!!!
Good luck, believe me its been a real UNESSESORY PAIN, felt like i was back in windows 98!
