Compatability problem with Accu-chek 360 diabetes software
2009-12-29T16:51:28+00:00
accu-chek 360 diabetes software will not install on windows 7. I contacted their technical support and they are working on windows 7 version but didn't know when it would be released. I'm currently using it on my wife's xp computer however it is with limited access. I really want to use it on my own computer.
First thought was to use virtual pc xp mode however my hardware doesn't support it. I'm looking for suggestions.
I'm thinking maybe I can get a third party virtual pc or virtual hard drive and install my oem copy of vista home basic on it.
 Don't know if this reinstall oem disc would work in this situation.
dell inspiron 1545 laptop
3g memory
160g hard drive (100g avail)
windows 7 enterprise(32b)
thanks,
george
2010-03-04T18:07:06+00:00
You must copy the the file folder from CD 2 to the External Software folder on your hard drive:
 Place cd 2 in cd drive and copy the content from the external software folder of CD 2 to the external software folder in you folder that you created
So in the External Software folder under your Accu-check folder on your hard drive you should have 2 folders
Adobe Flash Player and Adobe Reader
2010-03-03T17:38:09+00:00
I have the answer,
  1. Copy all the files from cd 1 to a folder on your hard drive ( i created one on my desktop called Accu-check )
  2. Open the External Software folder in the folder location
  3. Place cd 2 in cd drive and copy the content from the external software folder of CD 2 to the external software folder in you folder that you created
  4. Get the orca msi edit program and install it.
 5. Use orca to edit the msi file in the file folder you copied all the files to from the CD's ( ACCU-CHEK 360.msi). look for launchcondition and make sure all of this is in there especially the last part or (versionNT=601) as thats what will allow you to install under Win 7 this is how it should look when you are done...  (VersionNT = 500 AND ServicePackLevel >= 4) OR (VersionNT = 501 AND ServicePackLevel >= 2) OR (VersionNT = 502 AND ServicePackLevel >= 1)OR (VersionNT = 600) OR (VersionNT = 601)DO NOT CHANGE ANYTHING ELSE!!!
Do a "save as" and over wright the ACCU-CHEK 360.msi file in the file folder on your PC
Run the setup.exe from the file folder you copied all the files to and follow the install instructions... i have successfully intalled on 3 different win 7 PC's you will need to put in your activation key witch is on the back of the book that the CDs are in lower right very small hard to read but it is there.
You can copy the contents of your file folder to a DVD or flash drive and use that to install on other PC's if you want.
you are all welcome....
2009-12-30T16:07:22+00:00
Hi george1009,
Welcome to Microsoft Answers.
****As you have already contacted the manufacturer for details I would suggest you to stay in touch with them and then install the latest version on Windows 7.
The reinstall OEM disc would not help. The reinstall Vista OEM disc would set the computer back to factory shipped condition. The software is also not listed as compatible with Windows Vista at any stage. For more information about vista compatibility with the software it would be better to take assistance from the manufacturer.
Also, using Third Party Software, including hardware drivers and software can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the use of Third Party Software can be solved. Using Third Party Software is at your own risk.
Hope this helps. Let us know the results.
Meghmala – Microsoft Support
69 additional answers
    2009-12-30T17:35:51+00:00
    thanks for the response.
    I thought that would be the answer but was hoping. I guess I'll have to use the old computer for now. accu-chek has no idea when their vendor will get around to windows 7, but said they would send me a new cd as soon as available.
    my son (network engineer and head system administrator) looked at the program this morning to see if there was a workaround. he discovered that the program .ini files look for exact match operating system and exact match windows installer version (3.xx).  After digging around for about an hour he gave up. There apparently were many instances of the program looking for specific things in the operating system. He was able to workaround several things but seemed like too many to keep going.
         He has some new software at work they are going to start testing so he will check to see if it might be a solution. (I thought he said it was legacy application emulation. Didn't understand what he was trying to tell me but sounded interesting.)
        My wife commented that 20+years ago that it was my son looking over my shoulder (dos 5.x) and today it is me looking over his shoulder.(windows 7) makes me feel ancient in th software world.
    again thanks for the response.
    george
    2010-01-08T22:49:13+00:00
    Hello George,
    I also have the same problem as you with Windows 7 and Accu-Chek 360 Software.  I already attempted it with Virtual XP mode and it didn't work.  I am going to try to contact Accu-Chek to see what all they are checking with the installation software.
