updates not responding error code 80070641
2009-03-15T14:13:54+00:00
I receive the following error code for updates 800 70641
2009-03-15T23:04:04+00:00
Welcome to the Microsoft Windows Vista Communities site.
Windwos Update Error 0x80070641
The definition of the error code you’ve received 0x80070641 can be found below:
ERROR_INSTALL_SERVICE_FAILURE - The Windows Installer Service could not be accessed. This can occur if the Windows Installer is not correctly installed.
If you can successfully install applications that rely on the Windows Installer then the service itself is most likely functional, and was simply in use at the time of the update. Thus, you will want to make sure that the Windows Installer service is not in use prior to attempting updates.
If the issue persists after you’ve confirmed no installations are taking place proceed with the troubleshooting below.
How-to stop the Windows Installer service.
If you are sure no installations or configurations, which rely on the Windows Installer, prior to updating you can try manually stopping the Windows Installer service, and then attempting Windows Update. If the error code persists after that the issue may be related to a corrupt or otherwise damaged Windows Installer.
Stop the Windows Installer service and then use Windows Update…
1.    <br>Click<br>Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.<br><br><br>2.    <br>At the<br>Command Prompt window type the following, and press Enter:<br><br><br>3.    <br>net stop msiserver<br><br><br><br><br> Note:<br>This will effectively stop the Windows Installer service. This service will load-on-demand so manually stopping it does not adversely affect the computer. <br> --- <br><br><br><br>4.    <br>Launch<br>Windows Update, and then attempt to install the previously failed updates.
If this troubleshooting does not address your present error code please let the community know. Be sure to include all relevant information, and the steps you’ve already taken to try resolving this issue. Please include the results of the troubleshooting I’ve provided, and we would be more than happy to assist you further.
[Jared
Microsoft Answers Support Engineer Posting to you from Windows 7!
51 additional answers
    2012-04-17T18:32:52+00:00
    Hi RobertBoyles,
    The next step, since none of the troubleshooting steps resolved your issue, is to perform an InPlace Upgrade. Follow the steps in the link that best fits your version of Windows. If you still have issue with Windows Updates after this step, you will need to perform a clean installation of Windows.
    Before performing major troubleshooting steps, it is best to make sure you have a recent back up of your personal data and have a way to reinstall any software currently on the computer.
    Windows XP Repair Installation/InPlace Upgrade
    Windows Vista or Windows 7 InPlace Upgrade
    2012-04-18T05:28:26+00:00
    Does not work. It says the specified service does not exist as an installed program. It also says system error 1060 has occured.  I've had it with Microsoft and Dell.  Apple is looking real good to me.
    2012-04-22T13:38:26+00:00
    Hi The Micksterr,
    Although similar, your issue may be different from the original issue in this thread. Please create a new thread here and include the following information:
    • The complete version of Windows you have installed
    • The update(s) that are failing to install
    • The complete error message(s) received
    • Any troubleshooting steps you have complete
