updates not responding error code 80070641
2009-03-15T14:13:54+00:00
I receive the following error code for updates 800 70641
2009-03-15T23:04:04+00:00
Welcome to the Microsoft Windows Vista Communities site.
Windwos Update Error 0x80070641
The definition of the error code you’ve received 0x80070641 can be found below:
ERROR_INSTALL_SERVICE_FAILURE - The Windows Installer Service could not be accessed. This can occur if the Windows Installer is not correctly installed.
If you can successfully install applications that rely on the Windows Installer then the service itself is most likely functional, and was simply in use at the time of the update. Thus, you will want to make sure that the Windows Installer service is not in use prior to attempting updates.
If the issue persists after you’ve confirmed no installations are taking place proceed with the troubleshooting below.
How-to stop the Windows Installer service.
If you are sure no installations or configurations, which rely on the Windows Installer, prior to updating you can try manually stopping the Windows Installer service, and then attempting Windows Update. If the error code persists after that the issue may be related to a corrupt or otherwise damaged Windows Installer.
Stop the Windows Installer service and then use Windows Update…
1.    <br>Click<br>Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.<br><br><br>2.    <br>At the<br>Command Prompt window type the following, and press Enter:<br><br><br>3.    <br>net stop msiserver<br><br><br><br><br> Note:<br>This will effectively stop the Windows Installer service. This service will load-on-demand so manually stopping it does not adversely affect the computer. <br> --- <br><br><br><br>4.    <br>Launch<br>Windows Update, and then attempt to install the previously failed updates.
If this troubleshooting does not address your present error code please let the community know. Be sure to include all relevant information, and the steps you’ve already taken to try resolving this issue. Please include the results of the troubleshooting I’ve provided, and we would be more than happy to assist you further.
[Jared
Microsoft Answers Support Engineer Posting to you from Windows 7!
51 additional answers
    2011-09-07T16:36:42+00:00
    I am having the same difficulties with 2 updates pertaining to Microsoft Windows 2007.
    I have Windows Vista 32bit.
    The 2 updates which refuse to upgrade are as follows:
    Update for Microsoft Office 2007 System (KB2539530)
    Security Update for the 2007 Microsoft Office 2007 System (KB951944)
    I'm getting the same error code 80070641.
    Have tried stopping the Windows Installer, and changing it from manual to automatic.
    All help gratefully received.
    Many thanks
    2011-10-12T11:18:43+00:00
    I did do everything what was written (stop the installer) but i still have the same error message
    WindowsUpdate_80070641" "WindowsUpdate_dt000
    what can I do else?
    2011-12-13T22:44:33+00:00
    I got it fixed by going to http://www.microsoft.com/download/en/search.aspx?q=windows%20installer and installed **Windows** **Installer** 4.5 Redistributable and it took care of the problem. now everything installs successfully. Thanks for the help!
    2011-12-13T22:48:06+00:00
    what can I do else?
    go to http://www.microsoft.com/download/en/search.aspx?q=windows%20installer and download and install **Windows** **Installer** 4.5 Redistributable, restart pc and run update, it worked for me, i had 20 updates that were failing and now its successful.
