Unable to connect to company wireless network after Win7 upgrade
2009-11-06T21:58:16+00:00
My company network does not broadcast the SSID, so on Vista I used to manually setup the connection.  However with Win7 64 I keep getting an error that "An unexpected error has occurred"
Dell xpsM1330
Intel WiFi Link 4965AGN
Any help would be appreciated.
2010-10-20T22:17:06+00:00
Ok, let's see if we can keep this active and get to a fix...
Got an MS POC to give me some info that may help....
I've experienced what many above have, that while I can connect to most wireless networks, including my home wpa2, any time I tried to make a connection my corporate wpa2-enterprise network, no go, and had the errors in the event log. also similar failures whenever I'd try to create any wireless profile manually using wpa-enterprise or wpa2-enterprise.
Note mine was also a machine that got USMT data migrated, and I have a feeling it was responsible for migrating the keys below...
So here was the final fix, and maybe you guys can verify if it's the only thing needed as I'd tried various other things to no avail, but this was the "last" change I made that got things working...
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\RasMan\PPP\EAP
under here are a number of subkeys with different numeric values....
while I can't tell you specifically what to look for, in my case I noted there was one key pointing at what I'd expect, a ras related key in the windows\system32 dir. however, I also had three other keys pointing to files related to Symantec, which I did not have on my newly built machine.
So I exported keys from a newly built machine, that actually had symantec. it had four keys under EAP, but only one, the last one, was related to Symantec, all others pointed to files in system32.
I imported those keys into my broken machine, deleted the one key that was related to symantec, and without even having to reboot...all was fixed...
so....here's my suggestion, and I hope if this works everyone can feedback so we have more info on if it's the order of the keys or just the presence of bad entries...but I would suggest, starting off by looking at your keys under EAP, and seeing if there's anything referencing dll files that may not exist on your machine.
if you do have these keys, either delete the key, or try to put the file back in place thats being referenced, assuming it's missing.
we'll be doing some more testing internally, so I'll feed back if we have any additional findings.
good luck.
49 additional answers
    2010-07-22T23:50:18+00:00
    Found it!
    The problem is probably about the data saved about the following network.
    Go to start menu>control panel>network and internet> network and sharing center>manage wireless networks>delete the network you have a problem with then simply restart your computer and thats it.
    I wish that was helpful.
    2010-07-24T17:27:33+00:00
    Sorry to say that I tried that one to.
    The only way for me, was a reinstall. Now it works....
    Strange....
    2010-08-25T04:56:13+00:00
    I am not sure that it will help with the lost network connectivity (for that I am lucky that the built-in troubleshooter in Win 7 has always worked).
    But for people tired of all those eaphost 2002 errors: go to the registry and look under
    HKLM\System\CCS\Services\Eaphost\Methods
    Some of the keys and subkeys in that section will match the AuthorIDs and TypeIDs in the detailed XML view of the error seen in Event Viewer. You will see that in each case a path setting points to a non-existant folder (and dll file). These keys were possibly carried over in the easy transfer process. They may also be the result of poor set-up routines by a maunfacturer that does not bother to tailor the driver installation for different configurations of a computer model that is sold with various wifi options. (It is easier for them to install all the drivers leaving you with the performance penalty and error messages. Most users will not know the difference, or if they ask they will be told "Don't worry, the event log shows errors that are not really errors".)
    In my experience each key with an incorrect path reference can be deleted. Back up first, just in case it does not work for you! Before you start deleting, note that you should still be left with one working key with a correct path reference for your current WiFi setup.
    That should get rid of the 2002 errors.
    2010-10-07T20:30:08+00:00
    Hi Everyone.
    I am having the same issue on windows 7. Tried R_G_B's option but that didn't work. Also tried 'upgrading' the Windows 7, and it worked once, and never again. Reinstalled all the network drivers as well.
    Not sure I want to reinstall, but I am beginning to think this is the only answer.
    Did anyone else find a registry or driver or anything else that helped?
    Also, I did use the Windows Easy Transfer. :(
