Changing from RAID to AHCI
2010-10-28T12:24:52+00:00
on my Dell E6510 I have my disk drive set to RAID mode. I have issues using the eSata port so I want to switch to AHCI. I followed the instructions here:http://support.microsoft.com/kb/922976. However when I boot my system after setting the disk mode to AHCI in the BIOS I see the Windows logo (using Win7 x64) and some seconds later I get a bluescreen with a message I can't read because the system is rebooting. Changing the BIOS back to RAID brings up the system again...
Anything I can do to make AHCI working?
Thomas Pagel
2010-11-03T18:05:23+00:00
Hi Thomas,
Thank you for your post.
I believe I have the solution to your problem and I verified it against a Dell machine that has similar controller with your machine. Changing from AHCI to RAID,http://support.microsoft.com/kb/922976 fix will work.
Changing from RAID to AHCI, you need one more step. Msahci driver requires Atapi.sys miniport to be loaded during boot as well. So you need to change theStart value to 0 for both of the following entries in your registry. You can use regedit.exe utility.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\msahci
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\atapi
Or you can also simply run the below command lines in an elevated window.
REG ADD HKLM\System\CurrentControlSet\Services\msahci /v Start /d 0 /f /t REG_DWORDREG ADD HKLM\System\CurrentControlSet\Services\atapi /v Start /d 0 /f /t REG_DWORD
Regards
54 additional answers
    2014-12-18T21:20:56+00:00
    For AMD chipset owners;
    If you install AMD Catalyst (chipset) drivers,you will find in your registry;
    HKLM\System\CurrentControlSet\Services\amd_sata
    and
    HKLM\System\CurrentControlSet\Services\amd_xata
    These driver packages also update the SATA/AHCI driver, so that's where the entries come from.
    This means you can disable all other possible boot-method entries,and shave a bunch of seconds off your boot time.
    Yes,i'm talking about changing startup to 3 for msahci,atapi,amdsata,nvstor,nvraid,iastor...the whole bunch.
    I'm now on my desktop after 13 seconds after the startup initiation screen!
    The unneeded methods are not being polled anymore i guess!
    This probably also works for any other kind of chipset, as long as you know which entries you have to keep enabled!
    p.s.
    Always make a restore point before tinkering with these!
    2014-12-19T17:42:41+00:00
    @mmmmmmmenno I haven't gone back in and changed the registry listing from 0 to 3 again as my boot times are extremely fast now. I too can be on a browser within 15 seconds after booting. The big thing I noticed was if I take the windows update to the newer AMD SATA driver it actually slows the machine down to SATA II speeds whereas rolling the IDE/ATA back to the Standard AHCI 1.0 Serial ATA Controller I once again get SATA III speeds and is recognised by the Samsung Optimizer as SATA III whereas before it wasn't and correspondingly gave slower read&write speeds. Those drivers didn't slow boots times just the R&W speeds.
     If I understand what you are saying in your post, if I go back and change; msahci,atapi,amdsata,nvstor,nvraid,iastor the whole bunch back to 3 in the registry settings, is that right? Wouldn't this defeat the AHCI BIOS settings? Or booting to AHCI mode then resetting the registry back to 3 in modify rather than 0. I'm a little fuzzy on absorbing what you are saying about ''changing startup to 3''. I also have an AMD gfx that likes to update chipset drivers but always forgo that selection and go with the gfx update only
    2015-03-02T19:38:11+00:00
    Thank you very much for posting this!  The Windows KB article you linked (which is also the first Google result) was useless.  The Fix-it that came with it didn't help either.  Please make the appropriate team update that page with the correct information; this would have avoided much frustration for many people.  I have reloaded a machine or two because of the incorrect information on that page.  That KB article doesn't even differentiate between ACHI and RAID, in addition to failing to mention the critical ATAPI driver.  Step 4 should read:
    1. Locate and then click each of the following registry subkeys, following steps 5–6 below for each:
        For ACHI:
        For RAID:
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\iaStorV
        They ought to add IDE to that list as well.  And if there are dependencies beyond the one for ACHI mentioned above, they should be listed too.  The Vista machine here that I just switched from RAID (as incorrectly configured by the manufacturer) to ACHI boots and loads things noticeably faster on ACHI now, and will hopefully stop randomly corrupting files.
    2015-03-12T07:41:01+00:00
    Hi Thomas,
    Regards
    This solution worked for me while converting a client's broken RAID 1 to AHCI.
    One disk in the array failed, and it was decided to dump RAID and use a better backup solution.
    After switching bios from RAID to AHCI, BSOD's prevented booting into the Win7 OS.
    I switched back to RAID in BIOS, booted into the broken array's OS on the surviving drive,
    applied this fix, rebooted and switched back to AHCI, the disk is now booting fine and running
    Win7  as normal.
    However, The IRST showed an error and couldn't start, so I removed IRST, and the system is running
    as normal now. I will soon attempt to re-install IRST and see if it will run properly, but haven't gotten that far yet.
    BIG THANKS for this solution!
    congo
