I've been having the same problem on my HP desktop running Vista home for a couple weeks. I read that someone fixed the same problem by updating some hardware firmware, so I opened Resource Monitor and started unplugging all my hardware one at a time. The instant I unplugged my Belkin USB network adapter, NT Kernel & System dropped down to 0% and my computer unfroze entirely. The same adapter has been causing me a lot of grief for months- it wouldn't respond every time my computer came out of standby. I'll be updating the driver and firmware to see if that helps - otherwise that garbage is going in the trash. I recommend disabling/unplugging hardware (especially if you have any with odd behavior) until the problem stops, then replacing or updating that hardware.
NT Kernel & System using 100% of CPU
I just bought a new laptop with Window Vista Basic. The laptop has 3 Gb ram. I was just reading an article on line and then I start to hear the laptop fan running like crazy. then I went to the Resource Monitor and there was an image/program that was using 95% of my cpu and it was my system with description of "NT Kernel & System". It has been going on for over 30mins. Other than restarting the computer, what can I do about this "NT Kernel & System" eating up 95% of my CPU?
Hello Dtsai,
Thank you for posting. What you just described seems to be some form of mal-ware trying to mascuerade as a legitimate windows service. Windows does have NT Kernel and also System, but they never show up together as one service, program, or file.
I highly recommend that you use your favorite anti-virus and anti-spyware program and do a full scan of your PC.
Please try the scan and let me know if this helps you
Zack
59 additional answers
2013-06-29T07:04:20+00:00 I have an old HP netbook, it does this occasionally, what I found is it's due to the SD card reader. A reboot force power down (holding down the power button) will be ok.
2014-05-11T01:10:53+00:00 Hello Dtsai,
Zack
I have the same problem on my HP Envy 17t Windows 8.1, I restarted it but its still rrunning. I tried Malwarebytes free version but it doesn't detect any malware or spyware
2014-08-26T02:59:23+00:00 I was reading what you had written about the NT Kernel & Systems .. I also have a Newer computer and was going in the control panel because it has moments .. I ran the malware program as suggested . I also left clicked and suspended the NT Kernel & System , that froze the hole computer .. I looked it Up . This was listed Under Blue screen for Toshiba ..
The NT operating system has 2 basic layers, the user mode and kernel mode. The user mode cannot directly access hardware, it is limited to an assigned address space and operates at Ring 3 (lower priority). If a user mode program has an error, then NT just halts the programs process and generates an Operation error, and as the application runs in its own virtual address, it cannot affect any other program. I also looked Up this ,,, In computing, the kernel is a computer program that manages input/output requests from software, and translates them into data processing instructions for the central processing unit and other electronic components of a computer. The kernel is a fundamental part of a modern computer's operating system.
.. Hope this helps ...
