The remote procedure call failed and did not execute
2010-02-01T07:42:52+00:00
whenever I go to update Windows 7 my new laptop freezes and the computer ends up not responding. Whenever I try to open my computer, documents, control panel or search the following error message appears The remote procedure call failed and did not execute
Reported
2010-02-02T01:06:17+00:00
Hi aaabbbcccdddeeefffggg,
Try the following steps :
Type Services into the start menu search box.
In Services, scroll down to "Remote Procedure Call" and make sure the status says "Started"
and set to Automatic.
The second "RPC Locator" should be set to "Manual".
If the issue persists, as a workaround you may perform an online scan on your computer and check if the error message is caused due to malware or any virus.
Now visit the below provided link to perform an online scan on your computer.
http://onecare.live.com/site/en-us/default.htm
Later try installing updates and check.
Azeez Nadeem - Microsoft Support
69 additional answers
    2013-02-12T10:23:27+00:00
    Hi Deepak,
    The thread on which you have posted is too old. To avoid confusion please start fresh creating a new thread so that we can guide you in a right direction.
    Link:
    http://answers.microsoft.com/en-us/windows
    Hope it helps.
    2013-02-18T19:44:01+00:00
    services is not opening what to do?
    2013-02-20T20:05:12+00:00
    Hi uroojfatima,
    The thread on which you have posted is too old. To avoid confusion, please start fresh creating a new thread so that we can guide you in a right direction.
    Link:
    Hope it helps.
    2013-04-23T14:03:37+00:00
    today i have the problem but i fix the problem
    Thanks so much! I thought I my com got hack or something
