I am having the same problems but I am unable to access the System File Checker as I am not able to do anything in the start menu.
I just wrote a post but I can't find it so I will tell you what is happening.
I have windows 7 home premium 64bit. I noticed the problem shortly after I began the recommended windows updates. There were a lot of updates but here are the ones that I saw in the installed list.
- microsoft codec pack x 86.msi
- microsoft codec pack amd 64.msi
I also installed an update for shockwaveinstallerslim.exe and uninstalled the following
- wlset.up-web.exe(not sure why)
- N360Downloader.exe(this was the trial version and I have N360 installer for the year)
I first saw problems with not being able to Shut down the computer. Then not being able to use the Action Center. Then the task manager stopped working, Then not being able to access any of my folders in the Start menu(Library, Music, etc) and when I
clicked on them I would receive the error message "The remote procedure call failed and did not execute"
I tried all of the solutions but I am unable to open action center or do anything in the start menu, including typing anything in search. I am able to download antivirus programs but they will not run.
I ran a full scan on Norton yesterday and it said it fixed 4 cookies.
Thank you in advance,
photocp
