The remote procedure call failed and did not execute
2010-02-01T07:42:52+00:00
whenever I go to update Windows 7 my new laptop freezes and the computer ends up not responding. Whenever I try to open my computer, documents, control panel or search the following error message appears The remote procedure call failed and did not execute
Reported
2010-02-02T01:06:17+00:00
Hi aaabbbcccdddeeefffggg,
Try the following steps :
Type Services into the start menu search box.
In Services, scroll down to "Remote Procedure Call" and make sure the status says "Started"
and set to Automatic.
The second "RPC Locator" should be set to "Manual".
If the issue persists, as a workaround you may perform an online scan on your computer and check if the error message is caused due to malware or any virus.
Now visit the below provided link to perform an online scan on your computer.
http://onecare.live.com/site/en-us/default.htm
Later try installing updates and check.
Azeez Nadeem - Microsoft Support
69 additional answers
    2012-06-11T17:59:31+00:00
    I did (the System File Checker scan) and it seems to be okay after the reboot...
    I wasn't able to access any of my document folders or drives, couldn't even open "My Computer" or the control panel without getting the error "The remote procedure call failed and did not execute".
    Although it seems to be okay now, I would still like more information on why this happened...this particular issue has never happened with any of my other OSs, so is it just a Windows 7 thing?
    2012-09-08T21:50:18+00:00
    Excellent!!!! it worked :)
    2012-09-10T07:31:54+00:00
    Hi Rcolon85,
    We are glad that the issue is resolved. If you face Windows issue in future let us know.
    The issue might have occurred due to corrupt system files.
    2012-10-04T16:50:06+00:00
    If you sorted it out, please at least provide a link to the forum that solved your problem.
