The remote procedure call failed and did not execute
2010-02-01T07:42:52+00:00
whenever I go to update Windows 7 my new laptop freezes and the computer ends up not responding. Whenever I try to open my computer, documents, control panel or search the following error message appears The remote procedure call failed and did not execute
Reported
2010-02-02T01:06:17+00:00
Hi aaabbbcccdddeeefffggg,
Try the following steps :
Type Services into the start menu search box.
In Services, scroll down to "Remote Procedure Call" and make sure the status says "Started"
and set to Automatic.
The second "RPC Locator" should be set to "Manual".
If the issue persists, as a workaround you may perform an online scan on your computer and check if the error message is caused due to malware or any virus.
Now visit the below provided link to perform an online scan on your computer.
http://onecare.live.com/site/en-us/default.htm
Later try installing updates and check.
Azeez Nadeem - Microsoft Support
69 additional answers
    2016-06-18T14:25:55+00:00
    The problem I have is when I try to load a movie from a flash drive I get remote procedure call failed.
    I clicked on the link but don't get anything close to an online scan.
    2016-07-05T12:55:24+00:00
    I had a disaster with a company holding themselves out as "Microsoft Certified."  I learned from MS that this is not true.  Be careful with any 3rd party software.  I checked out the ratings and they were not good
    2016-07-11T02:29:33+00:00
    I installed a program, a few days later I went to remove it and when I try to open control panel I get "The remote procedure call failed".  I have set the Remote Procedure Call and Remote Procedure Locator to "Automatic".  I verified that DCOM Server Process Launcher is at "Automatic", and verified that RPC Endpoint Mapper is "Automatic".   I have scanned with PC Matic and it cleans.  Still no Luck.  Windows 10
    I am unable to do the setting on Remote Procedure Call
    I cannot access Control Panel because the error prevents me from getting in.
    2016-09-15T16:49:46+00:00
    umm...hey ananya.i am not a techie guy (bear with me) but the problem was resolved when i performed an ordinary security scan.
