The remote procedure call failed and did not execute
2010-02-01T07:42:52+00:00
whenever I go to update Windows 7 my new laptop freezes and the computer ends up not responding. Whenever I try to open my computer, documents, control panel or search the following error message appears The remote procedure call failed and did not execute
Reported
2010-02-02T01:06:17+00:00
Hi aaabbbcccdddeeefffggg,
Try the following steps :
Type Services into the start menu search box.
In Services, scroll down to "Remote Procedure Call" and make sure the status says "Started"
and set to Automatic.
The second "RPC Locator" should be set to "Manual".
If the issue persists, as a workaround you may perform an online scan on your computer and check if the error message is caused due to malware or any virus.
Now visit the below provided link to perform an online scan on your computer.
http://onecare.live.com/site/en-us/default.htm
Later try installing updates and check.
Azeez Nadeem - Microsoft Support
69 additional answers
    2011-08-15T11:55:31+00:00
    Thanks so much! I thought I broke my computer or something, phew!
    2011-08-18T01:52:58+00:00
    I contected my laptop to my desk top using a homegroup.  Everything was working fine until Yahoo told me to update my browers.  Once i did that, I was unable to print from the web.  I can still print from MS Office.  I am soo frustrated.  I have changed my Homegroup and done everything I can think of to me it work again.  But, when I try to print from Exporer I am still getting a message that says "Call procedure failed" res://ieframe.dll/preview.js
    Can anyone help me fix it please.  I am using Windows 7 for my laptop and the other computer in my homegroup is Windows XP.
    2011-10-10T02:07:29+00:00
     i had the same problem too, but i did the following steps and it doesnt solves the problem, the explorer.exe won't start and give the error message "
    2011-10-15T10:47:15+00:00
    Thank you for visiting the Microsoft Windows Community site. In an effort to focus more attention on your particular situation, it would be best for you to post into a new thread. Creating new threads are done to mitigate confusion caused by more than one posting about similar topics, allowing us to focus on each customer individually
    Please post your new question here.
