System Restore Error Code: 0x81000203
2009-11-24T08:06:52+00:00
When I open system restore tab from system properties where we can switch system restore on or off it says Sys restore unexpectected error occur . Cannot scan drives The error code is as above > OS is Win 7
2011-05-15T09:52:22+00:00
This problem persist @ users who had instaled TuneUp Utilities 2009 / 2010 / 2011,
TuneUp Utilities 2009 / 2010 / 2011 Turbo Mode block system protection / restore.
Which Turbo Mode is on, turn off Turbo Mode and go to Windows / Control Panel / System and Security / System Protection and these not anymore " error code 0x81000203 "
Problem fixed.
2009-11-24T23:41:17+00:00
Hi svk1234,
Thanks for posting in Microsoft answers!
Check if Microsoft Software Shadow Copy Provider service is disabled.
This behavior is by design. Disabling System Restore will limits the ongoing usefulness of System Restore on the computer.
To re-enable, please try:
  1. Open gpedit.msc from Start Search box.
  2. Navigate to the following branch.
Computer Configuration\Administrative Template\System\System Restore.
  1. In the right pane, please configure the “Turn off system restore” policy. Please set it to Not Configured.
See the following link for similar issue : http://social.technet.microsoft.com/Forums/en/w7itprosecurity/thread/0f2eebbe-6cdf-4ecc-93af-9249b7339ec9
Hope this helped
Azeez Nadeem - Microsoft Support
142 additional answers
    2011-08-21T15:26:31+00:00
    My tech guy from Sony says I must do a reinstall of Windows 7 to recover system restore and many other files.  We both tried all of the solutions offered here to no avail.
    Must now proceed to backup and will do the reinstall
    2011-08-22T17:36:00+00:00
    Saying it's time to reinstall the O.S. means it's time to change your O.S.  This should never be the only option to having a product work as advertized.
    2011-08-22T18:30:52+00:00
    oh dear.  Upgrading Windows 7 Home Premium to Professional would help?  Which OS would?  I suppose you mean Linux or sell the computer and get a MAC
