System Restore Error Code: 0x81000203
2009-11-24T08:06:52+00:00
When I open system restore tab from system properties where we can switch system restore on or off it says Sys restore unexpectected error occur . Cannot scan drives The error code is as above > OS is Win 7
2011-05-15T09:52:22+00:00
This problem persist @ users who had instaled TuneUp Utilities 2009 / 2010 / 2011,
TuneUp Utilities 2009 / 2010 / 2011 Turbo Mode block system protection / restore.
Which Turbo Mode is on, turn off Turbo Mode and go to Windows / Control Panel / System and Security / System Protection and these not anymore " error code 0x81000203 "
Problem fixed.
2009-11-24T23:41:17+00:00
Hi svk1234,
Thanks for posting in Microsoft answers!
Check if Microsoft Software Shadow Copy Provider service is disabled.
This behavior is by design. Disabling System Restore will limits the ongoing usefulness of System Restore on the computer.
To re-enable, please try:
  1. Open gpedit.msc from Start Search box.
  2. Navigate to the following branch.
Computer Configuration\Administrative Template\System\System Restore.
  1. In the right pane, please configure the “Turn off system restore” policy. Please set it to Not Configured.
See the following link for similar issue : http://social.technet.microsoft.com/Forums/en/w7itprosecurity/thread/0f2eebbe-6cdf-4ecc-93af-9249b7339ec9
Hope this helped
Azeez Nadeem - Microsoft Support
142 additional answers
    2011-06-08T17:28:27+00:00
    I found a fix somewhere in this forum.
    It told me to type services.msc in the start menu search and press enter
    Right Click "Microsoft Software Shadow Copy Provider">properties>startup type (change to manual)>start this service, then change startup type to automatic. Hope this helps.
    2011-06-14T00:09:47+00:00
    Problem fixed.
     Thanx for figuring out the cause of the problem.you are genius man. Thanx a lot.
    2011-06-30T20:36:46+00:00
    I have Windows 7 Ultimate x64
    I was having this problem for a long time, after your suggestion I have done exactly what you said and problem solved. I have created system restore point and it worked and the grayed out options came back everything back to normal.
    Thank you very much for your help much appreciated.
