System Restore Error Code: 0x81000203
2009-11-24T08:06:52+00:00
When I open system restore tab from system properties where we can switch system restore on or off it says Sys restore unexpectected error occur . Cannot scan drives The error code is as above > OS is Win 7
2011-05-15T09:52:22+00:00
This problem persist @ users who had instaled TuneUp Utilities 2009 / 2010 / 2011,
TuneUp Utilities 2009 / 2010 / 2011 Turbo Mode block system protection / restore.
Which Turbo Mode is on, turn off Turbo Mode and go to Windows / Control Panel / System and Security / System Protection and these not anymore " error code 0x81000203 "
Problem fixed.
2009-11-24T23:41:17+00:00
Hi svk1234,
Thanks for posting in Microsoft answers!
Check if Microsoft Software Shadow Copy Provider service is disabled.
This behavior is by design. Disabling System Restore will limits the ongoing usefulness of System Restore on the computer.
To re-enable, please try:
  1. Open gpedit.msc from Start Search box.
  2. Navigate to the following branch.
Computer Configuration\Administrative Template\System\System Restore.
  1. In the right pane, please configure the “Turn off system restore” policy. Please set it to Not Configured.
See the following link for similar issue : http://social.technet.microsoft.com/Forums/en/w7itprosecurity/thread/0f2eebbe-6cdf-4ecc-93af-9249b7339ec9
Hope this helped
Azeez Nadeem - Microsoft Support
142 additional answers
    2015-05-20T17:14:30+00:00
    This problem persist @ users who had installed TuneUp Utilities 2009 / 2010 / 2011,
    Problem fixed.
    I was using Tuneup Utilities in Turbo mode and as soon as I put it in standard mode I was able to create a restore point. Thank you so much, DW
    2015-05-20T19:43:40+00:00
    Well I HAVE the error 0x80042302 Shadow Copy Service component error
    and the computer doesn't even FIND gpedit.msc
    Any other things I can try??  I can't even use BACKUP COMPUTER or any backup files to external hard drive.
    Things are a mess
    2015-05-21T04:41:32+00:00
    Emeline. Calm down. You have a different error to unable to restore type error.
    Go to this page on wiki errors. The page I show here is not live so copy the links or copy/paste the link to get there. Read the article first then start work.
    Davex4
