Please can you help me - I have an old programmes called Quicken 98 and my new windows 7 laptop won't let me load it on - how can I get this programme on my machine?
2010-01-14T21:21:45+00:00
Please can you help me - I have Quicken 98 and it won't load on my new Windows 7 laptop - I realise its a very old programme - but it is brilliant and I use it every day - I have the data stored on an external drive - I really need help with this please
ps My cassells dictionery disc won't load either - why do's this happen when the systems change - it really isn't fair
thank with kind regards
2010-01-15T16:19:14+00:00
Today, 64-bit processors have become the standard for systems ranging from the most scalable servers to desktop PCs. The way to take full advantage of these systems is with 64-bit editions of Microsoft Windows products.
The 64-bit systems offer direct access to more virtual and physical memory than 32-bit systems and process more data per clock cycle, enabling more scalable, higher performing computing solutions. There are two 64-bit Windows platforms: x64-based and Itanium-based.
x64 solutions are the direct descendants of x86 32-bit products, and are the natural choice for most server application deployments—small or large. Itanium-based systems offer alternative system designs and a processor architecture best suited to extremely large database and custom application solutions.
64 bit is a way of manipulating data and if something is currently 16 bit there is no way for you to upgrade them to 64. That is the job of the author of the product. You will have to contact them.
Frenchie
45 additional answers
    2012-01-21T12:22:21+00:00
    right click on the setup. exe file use properties then choose compatibility mode. choose the windows version, run the serup again. 98 based program may be too old to use.
    2012-01-21T21:15:25+00:00
    Mushroom Man's procedure sounds much more complicated than the one I used. I offer it here in case it helps any of the outstanding queries. I used it to install Quicken 98 on to a 64-bit Windows 7 Home Premium PC. It may or may not have been critical that I had a "Year 2000 Solution" disc supplied by Intuit and a 16-digit registration code supplied at some interim stage by a telephone helpline that no longer exists. If you have these two things, try my process.
    The 16-bit version of Quicken won't run on a 64-bit OS, and the Autorun version on the “Year 2000 Solution” disc is 16-bit. However, there is a 32-bit .exe file on the disc. Open its contents and look for the Win95 folder (the Win31 folder contains the 16-bit version). Open Win95 and double-click on “setup.exe”; choose Custom installation.
    The default destination folder for the installation is C:\quickenw, which has to be changed to C:\progra˜2\quickenw\ (progra˜2 should have the tilde at mid-height and is the DOS name for Program Files (x86), the correct folder for 32-bit applications in 64-bit Windows). Also, uncheck “install IE3” and check “install IE4” instead. Finally, when Windows tells you the programme is “not set up properly”, cancel this message; it's a lie.
    As for registering the product, I think the instructions on the disc are still valid; choose telephone registration and input the 16-digit code.
    Good luck.
    2012-01-23T04:40:03+00:00
    Hugh,
    Thanks for the details. I tried what you are doing when installing Quicken 98 Deluxe onto Windows 7 Professional, but don't think I tried changing the directory exactly as you specify. Anyway, what I did worked for me, and hopefully these various methods will give those interested more "aces in their decks," if you will.
    Regarding the 16 digit code --you must have the U.K. version? Here in U.S., if I'm not mistaken, there was only a 6 digit code. Not entering it didn't ever seem to prevent one from using the program; there was just no way to eliminate the annoying start up window to remind registration when the program was opened. I've read that the registration # was required in the U.K. to run the program after it was opened "x" number of times.
    Also, I had no Year 2000 Solution disc that you reference -it's possible that could have made a difference in ease of installing -hard to tell.
    Mushroom Man
    2012-01-23T13:13:14+00:00
    Hugh,
    ... Regarding the 16 digit code --you must have the U.K. version? Here in U.S., if I'm not mistaken, there was only a 6 digit code...
    Yep, I'm in the UK, from which market Quicken was withdrawn many versions ago, so we have no support and no newer version we can upgrade to. I believe I had a 6-digit authorisation code to begin with, but acquired the 16-digit code when reinstalling some time after 2000 (from a telephone helpline that then existed). You're right: UK users can proceed without a code but will be locked out of the programme after a certain number of uses.
    Hope these exchanges help a few other users get a little more life out of what is undoubtedly the best personal-finance programme to hit the market.
    Hugh
