I figured it out. At least this works for my machine.
Quick Fix... Once per session
- Right click on your Network Icon in the System Tray (The one with the red X on it)
- Chose Diagnose and Repair
- Pick the last option Reset Network Adapter
- Voila... you should have your internet back.
If that works, you probably have a problem with the settings for your network adapter. Here is my permanent fix
1) Click Start -> Search [Device Manager] enter
- Expand Network Adapters, and pick the enabled adapter
- RIght click and Open the Properties for it
- Click on the Power Management Tab.
- Uncheck the box for "allow the computer to turn off the device to save power"
- Press Ok and you are done
As I understand it, when you sleep / hibernate / Standby, if the power is turned off on the network adapter, you will lose your internet access. When you resume, just powering on the device is not enough. By Resetting the Network adapter, it forces it to
go through the entire bring up process. Before unchecking the box, I had to reset on every resume. Now I have been up and operational for 3 days with no problems.
