Print Spooler keeps restarting
2009-08-31T19:54:08+00:00
I screwed up my print spooler in windows 7. It's in a restarting loop and does not allow me to do anything. The fix it tool from Microsoft that usually works great and clears out all the print drivers so that I can start fresh does not work in windows 7.
How can I fix this issue in 7?
2009-09-01T11:23:56+00:00
Hello Methodman85,
 Thank you for using Microsoft Windows Forums.
 Sorry you are having this problem with your printer.  I would suggest submiting your question at the link below for Windows 7 Forums.  You can also search FAQ's as well as submit a question.  Thanks!
Windows 7
http://social.technet.microsoft.com/Forums/en/category/w7itpro/
I would also try the steps below to see if this helps out.  This is from the same site where the Fix It tool is located.
http://windowshelp.microsoft.com/Windows/en-US/Help/8c11977e-8244-408f-a036-7978a618d7a21033.mspx#EOD
A print spooler is software that temporarily stores print jobs on the computer hard disk or in memory until the printer is ready to print them. If you've been waiting an unusually long time for a document to print, or if you see an error message about the print spooler, spooler subsystem, or spooler resources, you might need to change and then restart the Print Spooler service on your computer.
To do this, we recommend that you save your work, and then restart the computer to restart the Print Spooler service. If you don't want to restart the computer, try these steps instead.
 To change or restart the Print Spooler service
 You must be logged on as an administrator to perform these steps.
1.  Open Administrative Tools by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking Administrative Tools.
2.  Double-click Services.  If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3.  Right-click the Print Spooler service, and then click Properties.
4.  On the General tab, next to Startup type, make sure that Automatic is selected.
5.  If the service is not already running, under Service status, click Start, and then click OK.  If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
James Microsoft Answers Support Engineer Visit our Microsoft Answers Feedback Forum and let us know what you think.
46 additional answers
    2010-11-30T17:55:00+00:00
    Deleting everything in
    C:\Windows\System32\spool\PRINTERS
    completely solved the problem.
    Thomas
    DELL optiplex 780
    Windows 7 professional
    KonicaMinolta MC2300DL
    2010-12-16T18:43:33+00:00
    Sir
    Could you please take me thru step by step on how to accomplish this. I am not the most computer literate. Thank You.
    2010-12-18T03:28:59+00:00
    Hey,
    Goto the Start Menu and in Run type "cmd", if you are using Windows Vista or Windows 7, search "cmd" and then right-click and click "Run As Administrator" and allow the program to run.
    Then type the following statements:-
    net stop spooler
    del /Q /F /S "%systemroot%\System32\Spool\Printers\*.*"
    net start spooler
    Hope this helps! :D
    Akshit Soota
    2011-01-16T16:31:59+00:00
    Thanks!  This worked for me!  Printing just fine now ... after deleting everything in c:\windows\system32\spool\printers
