Device Drive Software not sucessfully installed -Code 39- Optiarc DVD +-RW AD 7580A ATA Device
2008-12-26T05:49:52+00:00
Need Help !
Recently purchased a Dell Inspiron 1525 Laptop using Vista operating system.
The DVD +-RW Device was working but has recently failed.
The Device Manager locates the Driver which is Optiarc DVD +-RW AD 7580A ATA Device
The Device Manager has a (-) marker which tells me the driver is not working.
I tried to update this driver but message received is "most recent driver already installed".
I opted to uninstall driver and restarted system.
Upon restart, system attemped to reinstall driver for my CD Rom.
I then received message " Drive device software was not sucessfully installed".
Also received message "Wndows cannot load the device for this hardware. Code 39"
At present my CD Rom device will not work.
I would appreciate anyone who has a solution to this problem.
Thank you in advance.
2008-12-26T13:22:47+00:00
Did you recently install some new burner software? Several of the burner installs can cause error 39. You sould rightclick this link to another Answers thread about removing the "Upper Filters" and "Lower Filters"entries. You can remove those by creating the CMD file I will paste in below, created by William Keener.
  1. Carefully copy, and then paste the following three commands into Notepad:
reg export HKLM\SYSTEM\CurrentControlSet\Control\Class{4D36E965-E325-11CE-BFC1-08002BE10318}\ %userprofile%\desktop\CDFiltersBackup.reg
reg delete HKLM\SYSTEM\CurrentControlSet\Control\Class{4D36E965-E325-11CE-BFC1-08002BE10318}\ /v UpperFilters /f
reg delete HKLM\SYSTEM\CurrentControlSet\Control\Class{4D36E965-E325-11CE-BFC1-08002BE10318}\ /v LowerFilters /f
  1. Save the file on your desktop as DeleteCDFilters.cmd.
  2. Right-click the DeleteCDFilters.cmd file on your desktop, and then click Run as administrator.
Note After you run this script, any programs that installed custom CD/DVD filter drivers may not be able to use your CD/DVD until your reinstall those programs. If the command script doesn't resolve the problem, you can simply restore your custom CD/DVD Filter drivers by double-clicking the CDFiltersBackup.reg that the command script exports to your desktop.
<end quote>
(Soon we will be seeing a "FixIt4Me" button from his team to do this automatically.)
Mark L. Ferguson MS-MVP
61 additional answers
    2009-10-10T13:40:53+00:00
    Thank you so much!  This is the only thing I tried that worked!
    2009-11-25T14:06:53+00:00
    Hi! I following his notice about fix code 39. But my PC still get this problem. Can i ask why? If you guy know the answer, show me .Because i''m tired of it.Thanks
    2009-11-25T20:02:29+00:00
    Thanks Mark! Awesome program and solved it super quick! would never of guessed how to fix the issue in a million years!!
    2009-11-29T13:17:58+00:00
    You might be able to uninstall the burner apps you have installed to solve this, also. Look at Programs and Features (or Add/Remove Programs) in Control panel, and uninstall any of those.
    Rating posts helps other usersMark L. Ferguson MS-MVP
