Device Drive Software not sucessfully installed -Code 39- Optiarc DVD +-RW AD 7580A ATA Device
2008-12-26T05:49:52+00:00
Need Help !
Recently purchased a Dell Inspiron 1525 Laptop using Vista operating system.
The DVD +-RW Device was working but has recently failed.
The Device Manager locates the Driver which is Optiarc DVD +-RW AD 7580A ATA Device
The Device Manager has a (-) marker which tells me the driver is not working.
I tried to update this driver but message received is "most recent driver already installed".
I opted to uninstall driver and restarted system.
Upon restart, system attemped to reinstall driver for my CD Rom.
I then received message " Drive device software was not sucessfully installed".
Also received message "Wndows cannot load the device for this hardware. Code 39"
At present my CD Rom device will not work.
I would appreciate anyone who has a solution to this problem.
Thank you in advance.
2008-12-26T13:22:47+00:00
Did you recently install some new burner software? Several of the burner installs can cause error 39. You sould rightclick this link to another Answers thread about removing the "Upper Filters" and "Lower Filters"entries. You can remove those by creating the CMD file I will paste in below, created by William Keener.
  1. Carefully copy, and then paste the following three commands into Notepad:
reg export HKLM\SYSTEM\CurrentControlSet\Control\Class{4D36E965-E325-11CE-BFC1-08002BE10318}\ %userprofile%\desktop\CDFiltersBackup.reg
reg delete HKLM\SYSTEM\CurrentControlSet\Control\Class{4D36E965-E325-11CE-BFC1-08002BE10318}\ /v UpperFilters /f
reg delete HKLM\SYSTEM\CurrentControlSet\Control\Class{4D36E965-E325-11CE-BFC1-08002BE10318}\ /v LowerFilters /f
  1. Save the file on your desktop as DeleteCDFilters.cmd.
  2. Right-click the DeleteCDFilters.cmd file on your desktop, and then click Run as administrator.
Note After you run this script, any programs that installed custom CD/DVD filter drivers may not be able to use your CD/DVD until your reinstall those programs. If the command script doesn't resolve the problem, you can simply restore your custom CD/DVD Filter drivers by double-clicking the CDFiltersBackup.reg that the command script exports to your desktop.
<end quote>
(Soon we will be seeing a "FixIt4Me" button from his team to do this automatically.)
Mark L. Ferguson MS-MVP
61 additional answers
    2010-06-07T11:45:30+00:00
    I started up my laptop (Dell D600 running Windows 7) and loaded the MagicISO virtual drive to run a BIN file only to realize it is not working. I checked and discovered that the CD (Samsung CDRW/DVD SN-324F ATA) and the virtual drives are no longer listed under My Computer. Disk Management drive scan did not detect any drive either. No error 39 came up though.
    I disabled System Restore prior **** to this time, so I could not do a system restore. I uninstalled the CDRW & MagicISO drive in Device Manager and restarted my laptop, the Device drivers for both drives were not successfully installed. I uninstalled the two programmes I installed just before the 'disappearance' of the drive icon. Still no disk drive icon.
    I then followed the Delete Upper Filter, Lower Filter Entry in regeditinstruction from this forum**.**The Lower Filter was listed in registry in my own case, I deleted that and restarted the system, the drive icons then came up.
    I later reinstalled the two programmes one after the other and found out that the ArcSoft Software Suite - PhotoImpression 5 ShowBiz DVD2 - was responsible. After the reinstallation I again checked the registry and deleted the Lower Filter value which had ArcSoft listed under it's Data column in registry. And now I have the software installed and my drives back and working fine.
    Thanks to all contributors to this forum.
    2010-06-16T17:54:23+00:00
    2. Right-click the DeleteCDFilters.cmd file on your desktop, and then clickRun as administrator.
    <end quote>
    Mark L. Ferguson MS-MVP ![](http://i3.social.microsoft.com/Image.avatr?size=Large&amp;user=Mark L. Ferguson&amp;id=fb4a4625-6789-43eb-aa48-4a1fbf2df947)
    Thanks Mark it help.Really appreciate it.
    2010-06-28T19:39:06+00:00
    Wow that fixed it for me too! Thanks so much. Still a mystery as to what happened to cause the problem in the first place. My DVD drive was working and then stopped, the only thing I can remember that I've done recently is to install Microsoft Office 2010.
    2010-07-20T03:31:07+00:00
    Thank you, you are the best! My last internal DVD drive pooped out and I just installed the new one. I could not get my computer to acknowledge the new drive or install the software. Removing the filters worked like a charm.
