System repair disc could not be created__The parameter is incorrect. (0x80070057)
2010-01-16T03:54:12+00:00
I get an error when I attempt to Create System Repair Disk in Windows 7 as follows:
Step 1: Press the Start button on your keyboard (the one that bears the Microsoft logo) or click the Start button from the bottom left hand corner of the screen.
Step 2: In the search box type in System Repair.
Step 3: Select Create a System Repair disk
Step 4: Take a blank DVD and put in the burning drive (DVD writer). You could also use a CD, just make sure it is large enough to store the System Repair Disc.
Step 5: Select the burning drive from the dropdown menu.
Step 6: Click Create disc.
A dialog appears immediately with the title "Create a system repair disc". It says
The parameter is incorrect. (0x8007057)
I verfied that the drivers on my Sony DVD RW drive are the most current, and I have no problems burning disks from other programs. I have tried using both CD-R and DVD-R media with the same result, but in fact the error appears so fast I don't think the drive is even accessed. There is nothing written to the event log.
Please help.
Windows for home | Previous Windows versions | Recovery and backup
2011-10-16T22:30:54+00:00
Hi Folks,
Also been caught by this error and could create a system image or system repair disk. Just as a last ditch effort I unmounted my encrypted partion (I use TrueCrypt to keep my company data safe) and so far it has bow at least allowed me to create a repair disk. I'm now going to try the backup without the encrypted drive mounted. I'll let you know if that succeeds. Not sure if the is the root cause of anyone else's issues but thought I'd post my findings...
Good luck...
Dave
54 additional answers
    2013-03-10T04:39:47+00:00
    Unbelievable....over 2 years later and no fix to this problem..... BILL GATES is a rock star!
    2013-03-10T04:43:27+00:00
    Apples and Oranges!.... I'm seeing apples in my future! The saying should be Apples and Lemons if it were to be more appropriate!
    2013-04-23T04:27:26+00:00
    And how do you know if you have truecrypt or not and how do you unmount
    2013-04-23T04:57:53+00:00
    True crypt is a program that you install onto
    your computer. So if you look in all your all
    programs menu or if you have installed true crypt
    then you should be able to look in the system tray,
    that it is on the right side of the windows taskbar
    and see if the truecrypt icon is there.
    Again you have to install truecrypt, so if you have
    ever installed it, then it should be there. Now if you
    never have installed truecrypt, then you should not
    have it. Hope this is found helpful.
    That's it for now. Take care till later.
    B4N Joel (aka joetom57)
