I get an error when I attempt to Create System Repair Disk in Windows 7 as follows:
Step 1: Press the Start button on your keyboard (the one that bears the Microsoft logo) or click the Start button from the bottom left hand corner of the screen.
Step 2: In the search box type in System Repair.
Step 3: Select Create a System Repair disk
Step 4: Take a blank DVD and put in the burning drive (DVD writer). You could also use a CD, just make sure it is large enough to store the System Repair Disc.
Step 5: Select the burning drive from the dropdown menu.
Step 6: Click Create disc.
A dialog appears immediately with the title "Create a system repair disc". It says
System repair disc could not be created
The parameter is incorrect. (0x8007057)
I verfied that the drivers on my Sony DVD RW drive are the most current, and I have no problems burning disks from other programs. I have tried using both CD-R and DVD-R media with the same result, but in fact the error appears so fast I don't think the drive
is even accessed. There is nothing written to the event log.
Please help.
