System repair disc could not be created__The parameter is incorrect. (0x80070057)
2010-01-16T03:54:12+00:00
I get an error when I attempt to Create System Repair Disk in Windows 7 as follows:
Step 1: Press the Start button on your keyboard (the one that bears the Microsoft logo) or click the Start button from the bottom left hand corner of the screen.
Step 2: In the search box type in System Repair.
Step 3: Select Create a System Repair disk
Step 4: Take a blank DVD and put in the burning drive (DVD writer). You could also use a CD, just make sure it is large enough to store the System Repair Disc.
Step 5: Select the burning drive from the dropdown menu.
Step 6: Click Create disc.
A dialog appears immediately with the title "Create a system repair disc". It says
The parameter is incorrect. (0x8007057)
I verfied that the drivers on my Sony DVD RW drive are the most current, and I have no problems burning disks from other programs. I have tried using both CD-R and DVD-R media with the same result, but in fact the error appears so fast I don't think the drive is even accessed. There is nothing written to the event log.
Please help.
Windows for home | Previous Windows versions | Recovery and backup
2011-10-16T22:30:54+00:00
Hi Folks,
Also been caught by this error and could create a system image or system repair disk. Just as a last ditch effort I unmounted my encrypted partion (I use TrueCrypt to keep my company data safe) and so far it has bow at least allowed me to create a repair disk. I'm now going to try the backup without the encrypted drive mounted. I'll let you know if that succeeds. Not sure if the is the root cause of anyone else's issues but thought I'd post my findings...
Good luck...
Dave
54 additional answers
  1. Deleted
    2010-01-16T16:48:04+00:00
    Same thing here. Win7 Pro 64bit. Pioneer DVD drive. Error "The parameter is incorrect. (0x80070057)" after following the same procedure as InnovativeOne above.
