Mouse settings not saved after reboot/restart
2008-12-29T04:56:46+00:00
I am changing the speed at which my mouse pointer moves across the screen.  I am 'applying' the change then selecting 'ok'.   The mouse point then moves faster as set.  Then after restarting/rebooting the computer, the mouse setting is back to the default slower movement speed.   The changes are not saved after the reboot.   What is preventing the mouse movement speed change from being saved?
2009-01-01T05:47:50+00:00
Mr. Brian,
  Please try the following steps.  Doing this should allow you to keep all the settings in the SetPoint software while at the same time resolving your issue.
   1. Click the Start orb, type msconfig in the Start Search box and hit Enter     If you are prompted for an administrator password or confirmation, type your password or click Continue 2. Within the System Configuration dialogue box, click the Startup tab
   3. Look for any entries named KHALMNPR or similar, and uncheck the box next to them (there may only be one)
   4. Click OK and restart your computer
   5.  After the restart, change your mouse pointer speed and restart
This should resolve your issue.  Please let us know.  Thank you.
Shane
47 additional answers
    2014-01-25T23:34:57+00:00
     Mr. Brian,
    Shane
    No such "KHALMNPR or similar" in msconfig/system congiguration/startup
    2014-01-25T23:46:17+00:00
    What worked for me (after no response from dumbass MS) was "WMPNSCFG".
    My apologies to other dumbasses.
    2015-01-29T22:15:59+00:00
    No such "KHALMNPR or similar" in msconfig/system congiguration/startup. In fact there's nothing; just a reference to 'Task Manager', where under 'Startup' I found my file. But it's 'Starting Impact' is not measured...
    -Neil
    2015-08-10T13:03:34+00:00
    My windows 10 msconfig takes me to task manager to manage start up, from there i dont have any files just the titles of programs and such, so i have no KHALNPR, what now?
