Mouse settings not saved after reboot/restart
2008-12-29T04:56:46+00:00
I am changing the speed at which my mouse pointer moves across the screen.  I am 'applying' the change then selecting 'ok'.   The mouse point then moves faster as set.  Then after restarting/rebooting the computer, the mouse setting is back to the default slower movement speed.   The changes are not saved after the reboot.   What is preventing the mouse movement speed change from being saved?
2009-01-01T05:47:50+00:00
Mr. Brian,
  Please try the following steps.  Doing this should allow you to keep all the settings in the SetPoint software while at the same time resolving your issue.
   1. Click the Start orb, type msconfig in the Start Search box and hit Enter     If you are prompted for an administrator password or confirmation, type your password or click Continue 2. Within the System Configuration dialogue box, click the Startup tab
   3. Look for any entries named KHALMNPR or similar, and uncheck the box next to them (there may only be one)
   4. Click OK and restart your computer
   5.  After the restart, change your mouse pointer speed and restart
This should resolve your issue.  Please let us know.  Thank you.
Shane
47 additional answers
    2008-12-29T10:47:27+00:00
    Do you have another user account that you can test this on to see if you have the same results with that account also?  Do other settings changes that you make save after you restart?  You could try reinstalling the driver for the mouse and see if that helps.  We have provided instructions for this below.
    Reinstall mouse driver:
        1. Click the Start orb, and select Control Panel.
        2. Within Control Panel click System and Maintenance
        3. Underneath Device Manager, click View Hardware and devices        If you are prompted, enter your Administrator password or click continue
        4. In Device Manager, expand Mice and other pointing devices    5. Underneath Mice and other pointing devices, right click the listed drive and choose Uninstall    6. Click OK    7.  Ckick Yes to restart your computer
    After the restart Windows Vista will reinstall the driver for your Mouse.  Please let us know if this resolves your issue.  Thank you.
    Shane
    2008-12-29T22:43:52+00:00
    I tried uninstalling the mouse driver.   This did not work.   Setting continued to change back to default after reboot.
    Also created 2nd user account and modified the mouse settings.   This account also showed the same behavior, the mouse setting changes were not saved after a reboot.
    Other possibilities?
    2008-12-30T04:44:05+00:00
    Hi Mr. Brian,
    Can you tell us the manufacturer of the mouse you are using? Also, is there any type of software installed that came with the mouse that you have?  Sometimes the software and Windows will conflict and this automatically resets the Windows settings after reboot.  Please let us know.  Thank you.
    Shane
    2009-01-01T04:48:28+00:00
    I have a laptop with a Synaptics PS/2 Port TouchPad V7.0.   Synaptics driver V10.1.7.0
    Also using a Logitech USB mouse with Logitech SetPoint software/driver v4.70.213
    Settings are not saved when using either the touch pad or the mouse.
