When using my microphone, the microphone level automatically adjusts.
2009-11-14T15:52:58+00:00
In order to fix it temporarily I have to right click the speaker icon in the tray, go to recording devices, double click my mic, go to the levels tab and readjust it. It becomes a huge problem when talking with the mic and the level goes from 100 down to 20 randomly and all of a sudden I can't be heard.
Sometimes it goes down right away, and I don't see a checkbox to disable this automatic adjustment.
I have unchecked allowing applications to take exclusive control but I'm not sure this is actually related.
2010-10-24T12:30:47+00:00
This has also had no affect on the problem.   Again I knew this would not help.   You see,  the above suggestion merely stops communications software adjusting the volume of other software items.
This problem is not related to the output volume of software being auto-adjusted.   It is to do with theinput level (sensitivity) of the microphone being auto-adjusted.
To try and clarify where the problem lies,  the input level that you see when you right click speaker icon,  select 'Recording Devices',  click the 'Recording' tab,  select the 'Microphone' and click 'Properties',  then click on the 'Levels' tab.   It is the 'Microphone' level there that is auto-adjusting.
Please note that this problem is related to the Microphone Input level.  Not a volume output level.
2010-10-30T12:05:40+00:00
Hi gerri,
To further clarify, are you saying that the volume slider in the microphone properties (pictured below) is auto-adjusting:
If yes, do you see the slider moving on it's on?
If yes, this is not a function of Windows 7 that I am aware of.
I suggest uninstalling Skype temporarily and restarting the computer to see if the issue resolves.
Chris
61 additional answers
    2015-05-30T03:35:10+00:00
    If you even looked honestly at the problem you´d realise the solution is to go to Skype settings and disable the automatic microphone volume adjust in the audio settings. Even if the settings in Win7 are right, automatic microphone adjust on Skype changes Win7 primary microphone settings. Have a nice day Support Enginner!
    2015-05-30T22:58:15+00:00
    Chris also assumed the OP was using Skype whereas s/he was actually using MSN Messenger. The auto-volume thing was a pain in that program.
    2015-07-14T16:28:58+00:00
    I don't think this has anything to do with Skype unless some properties are left even with uninstalling it.
    I have four "sound systems" on my Win 7 64bit ultimate PC.
    Connected TV graphics card HDMI.
    Terratec 6Fire USB,
    the motherboard Realtek
    the webcam mic.
    I uninstalled the web cam software. I uninstalled the Terratec software and unplugged all USB devices except mouse and keyboard.  Disabled the graphic's card sound. I disabled all sound features of the Realtek except the microphone.
    From Control Panel - Sound - Recording tab - select Microphone - click properties - click tab level. Change mic level to 100% and remove the mute. 10-30 seconds later level drops to zero and the mute is activated.  Unclick mute readjust levels to 100% and repeat every 10-30 seconds until it is dead that is no green bars. Fix this by unplugging mic and/or rebooting.
    Installed webcam, disable Realtek mic. See the level on the web cam mic adjust automatically to zero and engage mute.
    One suggestion is a virus - AVG didn't find any.  Ran a fix on the registry. Still the same problem. I have another Intel motherboard system with similar software (no Terratec USB sound system and a different Logitech web camera). It works fine. Even plugging in the same web camera and microphone.  Runs the same version of Skype (which I uninstalled on the faulty system). Even with setting all the auto adjust properties in Skype, checking all the boxes other posts tell us to uncheck.
    The system - in this hardware configuration has been running for over two years without issue. Unless it is a hardware failure (feature fault) or one of the updates which seems unlikely as the problem has been reported for several years.
    I might be forced to try a complete system disk format and re-install but this takes days to recover and weeks to get it to stop updating when shutting down and re-booting. There is nothing to indicate that the same fault will not re-occur if it is down to an update or a particular application being installed.
