Computer occassionaly freezes after being idle for a while.
2009-10-31T19:22:05+00:00
Freezes/locks up after being idle.  No applications running in the background.  Clean install of Win7 with no other issues noted on HP G60-120 laptop that was using Vista with no problems.  Will not unfreeze and have to power down and remove battery to reboot.
2009-11-05T18:57:29+00:00
Update: my system now no longer freezes after being idle.  But it still returns to the logon screen all by itself after 10 minutes or so of inactivity, even though all power mgt is disabled, and screensaver is set to "none".  This is in Windows 7, and did not happen when we had Vista on the machine.
Regarding the freezing behavior that used to happen, on my system I found that on one of our 4 users, the 'application data' folder was missing the security entry to Deny Everyone permission to “List folder / read data”.  As a result it seems that we had some kind of recursive/infinate loop going on, e.g. in a search a single file came up 17 times, with paths such as:
C:\Users\Barry\AppData\Local
\Application Data\Application Data\Application Data\Application Data\Microsoft\Windows
\Temporary Internet Files\Low\Content.IE5\HZTG9H19\ykb_popupWindow[1].js
I added the Deny entry to the security table to match the other users, and the computer doesn't freeze any more.  You might want to check your 'application data' file.  Step 1: in the file explorer click on 'organize' then folder & search options > view > show hidden files folders drives.  Step 2: go to \Users<user>\AppData\local.  Right click on the Application Data folder > properties > security > advanced, and make sure there is a "Deny" entry in the table.
2009-11-10T14:20:33+00:00
Hey Ryan MC,
Welcome to Microsoft Answers.
There could be various reasons for Windows feezing when idle. Here are few steps suggested to troubleshoot the above issue.
Step 1: Run Check Disk to check your hard drive disk for file system errors.
To do so,
1)       Open the Start Menu and click on the Computer button.
2)       Right click the hard disk drive that you want to check, and click on Properties
3)       Click on the Tools tab, and click on the Check now button under Error-checking.
4)       Check the box Scan and Attempt Recovery of Bad Sectors
This will automatically attempt to repair problems with files and folders that the scan detects.
5)       Click on Start to start scanning.
Depending upon the size of your hard disk, this may take several minutes to finish.
See if this resolves the above issue.
If this doesn’t, go to step 2:
Step 2: Perform Clean Boot:
This checks whether the problem is to do with third party software conflicts.
Here’s how you put your computer in clean boot state.
1)       Click Start, type msconfig in the Start Search box, and then press ENTER.
2)       User Account Control permission
3)       If you are prompted for an administrator password or for a confirmation, type the       password, or click Continue.
4)       On the General tab, click Selective Startup.
5)       Under Selective Startup, click to clear the Load Startup Items check box.
6)       Click the Services tab, click to select the Hide All Microsoft Services check box, and       then click Disable All.
7)       Click OK.
8)       When you are prompted, click Restart.
Now that your computer is in clean boot state, see if the problem recurs.
If it doesn’t, then we know for sure that a background program or startup item is causing this issue.
Follow the steps mentioned in the link below to find out the culprit.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
Having performed the above steps, make sure you return your computer to start normally.
Return the computer to normal startup mode.
To do so,
1)       Click Start, type msconfig.exe in the Start Search box, and then press ENTER.
2)       If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
3)       On the General tab, click the Normal Startup option, and then click OK.
4)       When you are prompted to restart the computer, click Restart.
If you still face issue after clean boot, then problem some of the system files might be corrupt.
To fix it, go to step 3.
Step 3: Perform SFC Scan.
Steps to perform sfc scan:
1.      Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2.      Click Continue or supply Administrator credentials if prompted.
3.      In the Command Prompt window type the following, and press Enter:
sfc /scannow
4.      You should see the following on-screen messages:
Beginning the system scan. This process will take some time.
Beginning verification phase of system scan.
Verification % complete.
5.      Once the scan has completed you will receive an onscreen message resembling one of the following:
…  found no integrity violations
…  found corruption but repaired it
…  found corruption that it could not repair
For more information visit website   http://support.microsoft.com/kb/936212
Regards,
Shinmila H - Microsoft Support
Visit our Microsoft Answers Feedback Forumand let us know what you think
140 additional answers
  1. Deleted
    2012-02-11T13:29:25+00:00
    Agreeing with bjbonder's reply here -the 'clean' install wasn't very clean.   To be honest, I did run the suggested utlity (Upgrade Advisor) prior to installation and it showed I might have some issues.  (I have an older Dell XPS 410 and was installing the 32bit version of Windows 7 Pro.)
         Once Windows 7 was installed initially, I encountered the freezes we're talking about.  I tried locating the problem over a several days and finally, in a fit of frustration, decided to re-install.
    It worked.
         My suggestion would be to run the Upgrade Advisor and, If it shows any issues whatsoever, do the 'clean' install option suggested by bjbonder where you format the partition before the actual installation of Windows 7 files begins.  (you will defintiely need to back up your files prior if you do this.)
        To do this, put the Windows 7 installation disc in the drive, shut the computer off and then, restart it.  while it runs through its startup routine, hit the f12 button to bring up the boot menu.  From there I select the cd/dvd drive and start the setup of Windows.
        When the app starts, one of the first input screens that pops up asks about the partition where you will install Windows 7.
         In my case, the partition I was  going to use was already selected but you can select whatever partition you want to work with manually if this is not what you want. While on this screen,  find the "Advanced Options" link at the lower right.  Click it and several other options come up including the one to 'format' the partition.
         You will be warned that you might lose critical information if you select the option and you must realize that once you format, you will not have the 'Windows.old' file to pull from after the installation.  So, be sure you back up the files you want/need and that you have installation discs available for all files and apps you plan to have onboard once your up and running.
         Then continue, following the instructions and install Windows 7 (hopefully) without any further complications.
         Thanks for the information presented here.  It helped alot.  I guess I would say there are many good suggestions of ways to rememedy the freezes.  By all means, try them for as long as your patience holds out.  When all else fails however, do a 'clean' install.
    2012-04-08T05:03:29+00:00
    Hi I have Window 7 Pro 64 Bit on an i7-2700k, ASUS P8p67Pro MB, 2 x 4Gb Ram(8GB), Nvidia 570. I previously had a Gigabyte MB in this rig until last month but as I had this problem as well as endless Bluescreen problems I finally got it swapped out.
    Totally clean install on a new MB, CPU and Memory but this problem has stayed.  All my other probs have gone away.
    The only thing the remains in my rig is 2 x 160GB WD Raptors Striped as OS drive, and 2 x 1TB WD Blues as my Work drive as well as the Nvidia 570.  Plus the case, keyboard and mouse.
    To re-articulate the problem.
    After being left on and unattended for 40mins to 2 hours the machine will not respond to input immediately.  I have changed all my power settings so that nothing sleeps. The problem still occurs.
    If on returning to the non responsive machine I press the Sleep button on my keyboard, after about 10-15 minutes the machine will go into a sleep. Pressing it again wakes it up an all is fine.
    No errors in the event log. But I'm pretty sure every time this happens I will see a "Windows error reporting service has entered the running state" and a corresponding "Stopped state".  Ive been monitoring it closely over Easter.
    As this problem has occured on both the old hardware setup and this setup I can discount the MB, CPU, Ram being the cause.  Drives are fine.  That leaves either my RAID config (Intel chipset), or Video Card or associated drivers as the cause.  As the problem seems to occur on ATI as well maybe the Video card can also be discounted.
    Lastly this problem does not occur when I boot from my XP partition. Repeating: This problem does not occur in Windows XP Pro 32 Bit on the exact same hardware and configuration.
    So simplly my conclusion is that this is a driver problem, or Windows 7 Pro issue.
    I work in IT and 2 people I know have the same issue.  They just ignore it an put it down to "It's Windows" and do a cold reboot.  I'm sure that is not a reputation Microsoft are happy to propogate around the Windows 7 experience.
    Any support of the currently support OS would be greatly appreciated.
    PS: There is no malware or virus on my system. I use MSE.
