Computer occassionaly freezes after being idle for a while.
2009-10-31T19:22:05+00:00
Freezes/locks up after being idle.  No applications running in the background.  Clean install of Win7 with no other issues noted on HP G60-120 laptop that was using Vista with no problems.  Will not unfreeze and have to power down and remove battery to reboot.
2009-11-05T18:57:29+00:00
Update: my system now no longer freezes after being idle.  But it still returns to the logon screen all by itself after 10 minutes or so of inactivity, even though all power mgt is disabled, and screensaver is set to "none".  This is in Windows 7, and did not happen when we had Vista on the machine.
Regarding the freezing behavior that used to happen, on my system I found that on one of our 4 users, the 'application data' folder was missing the security entry to Deny Everyone permission to “List folder / read data”.  As a result it seems that we had some kind of recursive/infinate loop going on, e.g. in a search a single file came up 17 times, with paths such as:
C:\Users\Barry\AppData\Local
\Application Data\Application Data\Application Data\Application Data\Microsoft\Windows
\Temporary Internet Files\Low\Content.IE5\HZTG9H19\ykb_popupWindow[1].js
I added the Deny entry to the security table to match the other users, and the computer doesn't freeze any more.  You might want to check your 'application data' file.  Step 1: in the file explorer click on 'organize' then folder & search options > view > show hidden files folders drives.  Step 2: go to \Users<user>\AppData\local.  Right click on the Application Data folder > properties > security > advanced, and make sure there is a "Deny" entry in the table.
2009-11-10T14:20:33+00:00
Hey Ryan MC,
Welcome to Microsoft Answers.
There could be various reasons for Windows feezing when idle. Here are few steps suggested to troubleshoot the above issue.
Step 1: Run Check Disk to check your hard drive disk for file system errors.
To do so,
1)       Open the Start Menu and click on the Computer button.
2)       Right click the hard disk drive that you want to check, and click on Properties
3)       Click on the Tools tab, and click on the Check now button under Error-checking.
4)       Check the box Scan and Attempt Recovery of Bad Sectors
This will automatically attempt to repair problems with files and folders that the scan detects.
5)       Click on Start to start scanning.
Depending upon the size of your hard disk, this may take several minutes to finish.
See if this resolves the above issue.
If this doesn’t, go to step 2:
Step 2: Perform Clean Boot:
This checks whether the problem is to do with third party software conflicts.
Here’s how you put your computer in clean boot state.
1)       Click Start, type msconfig in the Start Search box, and then press ENTER.
2)       User Account Control permission
3)       If you are prompted for an administrator password or for a confirmation, type the       password, or click Continue.
4)       On the General tab, click Selective Startup.
5)       Under Selective Startup, click to clear the Load Startup Items check box.
6)       Click the Services tab, click to select the Hide All Microsoft Services check box, and       then click Disable All.
7)       Click OK.
8)       When you are prompted, click Restart.
Now that your computer is in clean boot state, see if the problem recurs.
If it doesn’t, then we know for sure that a background program or startup item is causing this issue.
Follow the steps mentioned in the link below to find out the culprit.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
Having performed the above steps, make sure you return your computer to start normally.
Return the computer to normal startup mode.
To do so,
1)       Click Start, type msconfig.exe in the Start Search box, and then press ENTER.
2)       If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
3)       On the General tab, click the Normal Startup option, and then click OK.
4)       When you are prompted to restart the computer, click Restart.
If you still face issue after clean boot, then problem some of the system files might be corrupt.
To fix it, go to step 3.
Step 3: Perform SFC Scan.
Steps to perform sfc scan:
1.      Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2.      Click Continue or supply Administrator credentials if prompted.
3.      In the Command Prompt window type the following, and press Enter:
sfc /scannow
4.      You should see the following on-screen messages:
Beginning the system scan. This process will take some time.
Beginning verification phase of system scan.
Verification % complete.
5.      Once the scan has completed you will receive an onscreen message resembling one of the following:
…  found no integrity violations
…  found corruption but repaired it
…  found corruption that it could not repair
For more information visit website   http://support.microsoft.com/kb/936212
Regards,
Shinmila H - Microsoft Support
Visit our Microsoft Answers Feedback Forumand let us know what you think
140 additional answers
    2011-07-23T03:02:56+00:00
    I've had this same problem now and I am almost certain it was cause by a buggy windows update.
    I've reformatted 2x's now on a new 1.5tb drive and done 2 fresh installs of Windows 7 home premium x64-bit.
    After multiple hdd checks, virus scans, hardware checks, driver updates, the problem is still occurring.
    I have new ram sticks, checked timing settings, replaced the psu, checked the voltage settings on my cpu, checked the gpu, and closely watched core temps.  However after being idle for ~30 minutes, it still freezes. Ctrl + Alt + Del does not even pop up and the only fix is a hard reset.
    The latest SP from Microsoft still has not fixed this.
    Notes:
    I never enabled auto-hide on the taskbar, so disabling it is not a valid fix.
    I have turned off all power saving options and screensaver options.
    I tried the hotfix Microsoft released for a similar issue and could not even install it as it was included in the latest SP.
    I've updated all drivers and BIOS firmware.
    2011-07-26T04:18:56+00:00
    I am facing the exact same problem,What did you do to resolve your problem.
    Thank you in advance
    2011-09-03T16:56:02+00:00
    I would suggest very strongly that you take another look, at the Power Settings.
    If your computer is 'freezing up' (or, 'locking up'!) it is MOST probably BECAUSE your computer is going into SLEEP mode.
    This is BECAUSE 1 of the Power Settings is SET (STILL).....in the SLEEP mode.
    There are a few Power Settings that are NOT noticable visible.
    These are PRINTED in BLUE print.
    Go through them ALL, again, and, make sure that they are set correctly.
    It doesn't matter whether the computer is a Lap-top or Desk-top, but, SELECTING all as "Never" certainly does work for me!
    Your enquiry itself 'speaks' strongly of.........your lack of competent 'computer skills'!
    Otherwise you would not be asking 'how-to-fix' such a problem, right?
    Hint!
    Check your Vista-based lap-top out (the one that IS working RIGHT!)..........to VERIFY 'how' it's Power Settings ARE set up.
    Then, DUPLICATE them....on the computer that IS 'freezing/locking up'.
    Such a simple-n-easy task, yet, one made harder, much harder......................by always taking hardest way possible (AKA: the lack of 'good computering skills'!)
    Everything you need to know, is RIGHT in front of you......in your very own computer. (Only you can't be bothered ....to learn any of it!)
