Computer occassionaly freezes after being idle for a while.
2009-10-31T19:22:05+00:00
Freezes/locks up after being idle.  No applications running in the background.  Clean install of Win7 with no other issues noted on HP G60-120 laptop that was using Vista with no problems.  Will not unfreeze and have to power down and remove battery to reboot.
2009-11-05T18:57:29+00:00
Update: my system now no longer freezes after being idle.  But it still returns to the logon screen all by itself after 10 minutes or so of inactivity, even though all power mgt is disabled, and screensaver is set to "none".  This is in Windows 7, and did not happen when we had Vista on the machine.
Regarding the freezing behavior that used to happen, on my system I found that on one of our 4 users, the 'application data' folder was missing the security entry to Deny Everyone permission to “List folder / read data”.  As a result it seems that we had some kind of recursive/infinate loop going on, e.g. in a search a single file came up 17 times, with paths such as:
C:\Users\Barry\AppData\Local
\Application Data\Application Data\Application Data\Application Data\Microsoft\Windows
\Temporary Internet Files\Low\Content.IE5\HZTG9H19\ykb_popupWindow[1].js
I added the Deny entry to the security table to match the other users, and the computer doesn't freeze any more.  You might want to check your 'application data' file.  Step 1: in the file explorer click on 'organize' then folder & search options > view > show hidden files folders drives.  Step 2: go to \Users<user>\AppData\local.  Right click on the Application Data folder > properties > security > advanced, and make sure there is a "Deny" entry in the table.
2009-11-10T14:20:33+00:00
Hey Ryan MC,
Welcome to Microsoft Answers.
There could be various reasons for Windows feezing when idle. Here are few steps suggested to troubleshoot the above issue.
Step 1: Run Check Disk to check your hard drive disk for file system errors.
To do so,
1)       Open the Start Menu and click on the Computer button.
2)       Right click the hard disk drive that you want to check, and click on Properties
3)       Click on the Tools tab, and click on the Check now button under Error-checking.
4)       Check the box Scan and Attempt Recovery of Bad Sectors
This will automatically attempt to repair problems with files and folders that the scan detects.
5)       Click on Start to start scanning.
Depending upon the size of your hard disk, this may take several minutes to finish.
See if this resolves the above issue.
If this doesn’t, go to step 2:
Step 2: Perform Clean Boot:
This checks whether the problem is to do with third party software conflicts.
Here’s how you put your computer in clean boot state.
1)       Click Start, type msconfig in the Start Search box, and then press ENTER.
2)       User Account Control permission
3)       If you are prompted for an administrator password or for a confirmation, type the       password, or click Continue.
4)       On the General tab, click Selective Startup.
5)       Under Selective Startup, click to clear the Load Startup Items check box.
6)       Click the Services tab, click to select the Hide All Microsoft Services check box, and       then click Disable All.
7)       Click OK.
8)       When you are prompted, click Restart.
Now that your computer is in clean boot state, see if the problem recurs.
If it doesn’t, then we know for sure that a background program or startup item is causing this issue.
Follow the steps mentioned in the link below to find out the culprit.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
Having performed the above steps, make sure you return your computer to start normally.
Return the computer to normal startup mode.
To do so,
1)       Click Start, type msconfig.exe in the Start Search box, and then press ENTER.
2)       If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
3)       On the General tab, click the Normal Startup option, and then click OK.
4)       When you are prompted to restart the computer, click Restart.
If you still face issue after clean boot, then problem some of the system files might be corrupt.
To fix it, go to step 3.
Step 3: Perform SFC Scan.
Steps to perform sfc scan:
1.      Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2.      Click Continue or supply Administrator credentials if prompted.
3.      In the Command Prompt window type the following, and press Enter:
sfc /scannow
4.      You should see the following on-screen messages:
Beginning the system scan. This process will take some time.
Beginning verification phase of system scan.
Verification % complete.
5.      Once the scan has completed you will receive an onscreen message resembling one of the following:
…  found no integrity violations
…  found corruption but repaired it
…  found corruption that it could not repair
For more information visit website   http://support.microsoft.com/kb/936212
Regards,
Shinmila H - Microsoft Support
Visit our Microsoft Answers Feedback Forumand let us know what you think
140 additional answers
    2011-01-12T07:51:27+00:00
    Hi Aaron
    In my case it happened with an Acer Vista Ultimate that was two and a half years old, which I'd upgraded to Windows 7 Ultimate, so your reply might be relevant to that.
    However, I now have a brand new Toshiba with Windows 7 Home Premium OEM installed. I had exactly the same issues with this when it was brand new in November 2010. As I said above, based on various replies all over the web I stopped sleep, hibernation, disks turning off, display turning off and screensaver. When I did this on the Toshiba it stopped freezing and has been freeze free ever since.
    Regards
    Alan
    2011-01-12T14:18:16+00:00
    Hi Aaron,
    I followed your instructions and this is what I got. Could you analyze this for me, please?
    Regards,
    Veselin
    ________________________________________________________________
    C:\Windows>powercfg -a
    The following sleep states are available on this system:
    Standby ( S1 S3 ) Hibernate Hybrid Sleep
    The following sleep states are not available on this system:
    Standby (S2)
            The system firmware does not support this standby state.
    C:\Users\Veselin Marković\Desktop>powercfg -energy
    Power Efficiency Diagnostics Report
    Computer NameCOLOSSUS
    Scan Time2011-01-12T13:48:05Z
    Scan Duration60 seconds
    System ManufacturerSystem manufacturer
    System Product NameSystem Product Name
    BIOS Date01/25/2010
    BIOS VersionASUS M2N-E ACPI BIOS Revision 1703
    OS Build7601
    Platform RolePlatformRoleDesktop
    Plugged Intrue
    Process Count55
    Thread Count837
    Report GUID**{2605fbed-e6ad-42ed-a62a-0cf5613f8bf5}**
    Analysis Results
    Errors
    Power Policy:Sleep timeout is disabled (Plugged In)
    The computer is not configured to automatically sleep after a period of inactivity.
    Power Policy:Disk idle is disabled (Plugged In)
    The disk is not configured to turn off after a period of disk inactivity.
    USB Suspend:USB Device not Entering Suspend
    The USB device did not enter the Suspend state. Processor power management may be prevented if a USB device does not enter the Suspend state when not in use.
    Device Name USB Root Hub
    Host Controller IDPCI\VEN_10DE&DEV_036D
    Host Controller LocationPCI bus 0, device 2, function 1
    Device IDUSB\VID_10DE&PID_036D
    Port Path
    Device NameUSB Root Hub
    Host Controller IDPCI\VEN_10DE&DEV_036C
    Host Controller LocationPCI bus 0, device 2, function 0
    Device IDUSB\VID_10DE&PID_036C
    Port Path
    Device NameUSB Composite Device
    Device IDUSB\VID_046D&PID_C52B
    Port Path3
    Device NameGeneric USB Hub
    Device IDUSB\VID_0409&PID_005A
    Port Path1
    Device IDUSB\VID_046D&PID_C318
    Port Path2
    Device NameCSR Bluetooth Radio
    Device ID USB\VID_0A12&PID_0001
    Port Path1,1
    ReasonThis Bluetooth USB device does not support selective suspend because it is not self powered.
    Device NameAmerican Power Conversion USB UPS
    Host Controller ID PCI\VEN_10DE&DEV_036C
    Device ID USB\VID_051D&PID_0002
    Port Path4
    CPU Utilization:Processor utilization is high
    The average processor utilization during the trace was high. The system will consume less power when the average processor utilization is very low. Review processor utilization for individual processes to determine which applications and services contribute the most to total processor utilization.
    Average Utilization (%)8.41
    Warnings
    Power Policy:802.11 Radio Power Policy is Maximum Performance (Plugged In)
    The current power policy for 802.11-compatible wireless network adapters is not configured to use low-power modes.
    CPU Utilization:Individual process with significant processor utilization.
    This process is responsible for a significant portion of the total processor utilization recorded during the trace.
    Process Nameiexplore.exe
    PID 5052
    Average Utilization (%)2.81
    Module Average Module Utilization (%)
    \Device\HarddiskVolume2\Windows\SysWOW64\mshtml.dll 1.46
    \SystemRoot\System32\win32k.sys 0.47
    \SystemRoot\system32\ntoskrnl.exe 0.19
    Process Name iexplore.exe
    PID3552
    Average Utilization (%) 0.92
    \SystemRoot\system32\ntoskrnl.exe 0.21
    \Device\HarddiskVolume2\Windows\SysWOW64\mshtml.dll 0.11
    \Device\HarddiskVolume2\Windows\SysWOW64\jscript.dll 0.11
    Process Nameexplorer.exe
    PID3864
    Average Utilization (%)0.78
    \SystemRoot\system32\ntoskrnl.exe 0.29
    \SystemRoot\System32\win32k.sys 0.13
    \Device\HarddiskVolume2\Windows\System32\shell32.dll 0.06
    Process NameSystem
    PID4
    Average Utilization (%)0.51
    \SystemRoot\system32\ntoskrnl.exe 0.35
    \SystemRoot\system32\hal.dll 0.03
    \SystemRoot\system32\DRIVERS\atikmdag.sys 0.03
    Process Nameavp.exe
    PID1948
    Average Utilization (%)0.41
    \SystemRoot\system32\ntoskrnl.exe 0.15
    \Device\HarddiskVolume2\Program Files (x86)\Kaspersky Lab\Kaspersky PURE\icheck3.ppl 0.04
    \Device\HarddiskVolume2\Windows\SysWOW64\ntdll.dll 0.03
    Process Namedwm.exe
    PID1928
    Average Utilization (%)0.40
    \Device\HarddiskVolume2\Windows\System32\dwmcore.dll 0.16
    \Device\HarddiskVolume2\Windows\System32\atidxx64.dll 0.09
    \SystemRoot\system32\ntoskrnl.exe 0.02
    PID2280
    Average Utilization (%)0.30
    \SystemRoot\system32\ntoskrnl.exe 0.09
    \Device\HarddiskVolume2\Windows\SysWOW64\ntdll.dll 0.04
    \Device\HarddiskVolume2\Program Files (x86)\Microsoft Silverlight\4.0.51204.0\agcore.dll 0.03
    Process Namewlmail.exe
    PID3400
    Average Utilization (%)0.24
    \SystemRoot\system32\ntoskrnl.exe 0.05
    \Device\HarddiskVolume2\Program Files (x86)\Windows Live\Contacts\lmcdata.dll 0.03
    \Device\HarddiskVolume2\Windows\SysWOW64\ntdll.dll 0.02
    Process Namewlcomm.exe
    PID1784
    Average Utilization (%)0.22
    \Device\HarddiskVolume2\Program Files (x86)\Windows Live\Contacts\lmcdata.dll 0.04
    \Device\HarddiskVolume2\Windows\SysWOW64\kernel32.dll 0.02
    Process Namecsrss.exe
    PID572
    \SystemRoot\system32\ntoskrnl.exe 0.08
    \SystemRoot\System32\win32k.sys 0.06
    \SystemRoot\system32\DRIVERS\atikmdag.sys 0.04
    Information
    Platform Timer Resolution:Platform Timer Resolution
    The default platform timer resolution is 15.6ms (15625000ns) and should be used whenever the system is idle. If the timer resolution is increased, processor power management technologies may not be effective. The timer resolution may be increased due to multimedia playback or graphical animations.
    Current Timer Resolution (100ns units)156000
    Power Policy:Active Power Plan
    The current power plan in use
    Plan Name OEM Balanced
    Plan GUID**{381b4222-f694-41f0-9685-ff5bb260df2e}**
    Power Policy:Power Plan Personality (Plugged In)
    The personality of the current power plan when the system is plugged in.
    PersonalityBalanced
    Power Policy:Video quality (Plugged In)
    Enables Windows Media Player to optimize for quality or power savings when playing video.
    Quality ModeOptimize for Video Quality
    System Availability Requests:Analysis Success
    Analysis was successful. No energy efficiency problems were found. No information was returned.
    Battery:Analysis Success
    Platform Power Management Capabilities:Supported Sleep States
    Sleep states allow the computer to enter low-power modes after a period of inactivity. The S3 sleep state is the default sleep state for Windows platforms. The S3 sleep state consumes only enough power to preserve memory contents and allow the computer to resume working quickly. Very few platforms support the S1 or S2 Sleep states.
    S1 Sleep Supportedtrue
    S2 Sleep Supportedfalse
    S3 Sleep Supportedtrue
    S4 Sleep Supportedtrue
    Platform Power Management Capabilities:Processor Power Management Capabilities
    Effective processor power management enables the computer to automatically balance performance and energy consumption.
    Group0
    Index0
    Idle (C) State Count 1
    Performance (P) State Count6
    Throttle (T) State Count0
    Group0
    Index1
    Idle (C) State Count1
    2011-01-12T15:29:46+00:00
    Long awaited update on my own case.
    I've read over everything on this thread since my original post some months ago, and in my case, it can't be the BIOS as I did a BIOS flash update, then reinstalled windows 7 with no change. For those talking about the autohide feature of the taskbar, I never have that feature turned on, and this happens with a fresh clean install and no other software installed.
    After months and months of trying and getting frustrated, I removed windows 7 and reinstalled windows XP. My system runs perfectly fine with windows XP, and has higher compatibility with the programs I use anyway so I think I will just stick with windows XP. I refuse to use BETA software, so maybe when the service pack is released officially, i will try again. Microsoft's lack of action on this issue is very disconcerting.
