***** FIXED ********
I finally stumbled upon this thread:
and ran the System File Checke r. It found and fixed problems. I have no idea what the log means, but...
My Devices and Printers is now fully populated.
Regards,
Jeff
Hi All:
I sincerely apologize if my specific problem has been solved already. As the title indicates, when I open Orb -> Devices and printers it always shows up empty. I have tried every bluetooth related post including upgrading drivers, verifying the BT services (both) are running, the suggestion to use the IE8 registry cmd script etc. Virtually all the posts were point at BT, so I disabled, uninstalled all drivers, re-enabled it, re-installed, etc. At each step I tried the Devices and Printers with the same results.
Adding some details:
I AM PULLING MY HAIR OUT looking for a solution to no avail. I use Paragon Disk Backup so I don't mind hacking my registry or other configs and am brave enough (fool hardy?) to try just about any suggestions since I can always do a full restore of the OS Partition.
Truly appreciate any feedback. Please, no "check your BT services". Been there, done that.
Regards,
Jeff
Regards,
Jeff
I just tried this and this FIX works ..
Click Start button, type "services" into the search program and files box. This brings up a list in the menu, select Services. This should open a list of local services on your system.., Find 'Bluetooth Service" and make sure it has started, right click and set to 'automatic' (mine was already set), Select "Bluetooth Support Service" and start, set to automatic (mine was set on manual) --
Really wierd. Debleena, can you please explain.
Regards,
Rakesh
that's all well and good, but what if we don't want the Bluetooth service to be running?
With my laptop, I have to have the Wifi turned on to avoid this problem. For some reason, the Bluetooth service will not run if the wifi radio is turned off. So to have the bluetooth service on, I have to have the wifi on, which sometimes presents other problems when you are on a wired network.
I tried to get Microsoft to give me the Bluetooth quickfix they describe in the tech bulletin (http://support.microsoft.com/kb/2486635,) but after Eleven (11) calls to support, and explaining the problem Eleven (11) times to different agents who all said "I will have to get you to a different group" and then either getting transferred to the same group or getting cut off or left on hold for 20 minutes or more, I gave up trying.
To answer the previous question:
There's always the company named after the fruit. This is a perfect example of why fruit might be a better, simpler and more elegant choice. How much time do I waste daily/weekly/monthly trying to get around Microsoft problems and issues vs how much more I would pay for the hardware and software? In the long run, how much more productive work I would have done?
It's also quite telling that the post above marked "answer" has not been marked "helpful" by anyone.
I think its terribly funny that less than 24 hours after i made the above post, (see the last line above) "magically" 7 people have clicked on "I have this problem too" and ALSO 7 people have just now clicked on the "Yes" this was helpful. Obviously someone is stacking the deck here.
Just for the record, I tried both of the reputed solutions and neither one directly solved my problem.
My problem was mostly solved by enabling my hardware WiFi connection (using fn+F2 on my Dell laptop). Then after stopping the "print spooler" service (it usually doesn't stop but gives a timeout message saying it couldn't stop it) and then starting it again I was able to see the list of printers.
The problem sometimes still occurs when I restart Windows, and I have to follow the stop and start 'print spooler' to get it working.
