The volume control icon has disappeared from the taskbar
2008-12-11T19:26:38+00:00
My volume control button has dissapeared from the bottom right hand corner of my screen - how can i get it back?
2008-12-11T19:27:28+00:00
Dont Worry....... Just rightclick on taskbar---->properties----->select Notification Area Tab--------->In system Icon select "volume" ................I hope it will help u........
Another community answer from the Windows Vista newsgroups
100 additional answers
    2010-03-31T14:23:16+00:00
    When I downloaded a new driver for my speaker system and rebooted, the grey areas in the display area dissapeared. I was then able to click on the volume box and the speaker icon reappeared in the system tray area.
    D
    2010-04-21T00:10:02+00:00
    thanks it worked and was so easy!
    2010-05-08T11:27:03+00:00
    i have tried this method and it did not work. the  icone came up and said ok or cancel, nothing about the volume.
    2010-05-08T22:36:55+00:00
    Thanks   I got it back.  Your instructions were right on, but the volume and its ativate box came out in gray and would not accept a check...  So i restarted the computer and bingo  there was the icon.  Happiness!!
