Dont Worry....... Just rightclick on taskbar---->properties----->select Notification Area Tab--------->In system Icon select "volume" ................I hope it will help u........
Another community answer from the Windows Vista newsgroups
My volume control button has dissapeared from the bottom right hand corner of my screen - how can i get it back?
Same issues as earlier posts of jerbunk and tkittrell. New HP, after updates the volume and the network icon went missing. After two reboots, still missing. Just now after reading above, went back to system tray notification icons and was able to put checks in the boxes next to volume and network. Icons are now back. Thanks!!
i did as indicated but it wont work it wont let me click on it what's next ?
Hi victoria123,
See my reply above which shows you how to deal with it using several methods including
when it is grayed out.
Hope this helps.
Rob - Bicycle - Mark Twain said it right.
When I downloaded a new driver for my speaker system and rebooted, the grey areas in the display area dissapeared. I was then able to click on the volume box and the speaker icon reappeared in the system tray area.
D
