Move or copy a print job to another printer
2009-04-02T03:30:57+00:00
Is it possible to move or copy a print job to another printer?  My problem is I printer a few documents from the web to a printer that was offline (not plugged into my USB port).  Is it possible to move or copy those print jobs to another printer I have on my system?
2009-04-02T10:49:39+00:00
Hello mjpalm,
Typically if you reconnect the printer, the print job will still be in the spooler for that device. If when you reconnect the printer the job does not print automatically you go into the print properties for that printer, right click on the print job and click restart.
At this time there is no function to grab print jobs from one print queue and place them in another print queue.
Judd
Microsoft Answers Support Engineer Visit our Microsoft Answers Feedback Forum and let us know what you think.
41 additional answers
    2012-10-04T17:00:30+00:00
    Daniel, your suggestion totally saved my document.  Thanks so much!  I also was working with two of the same printer so not sure about whether it would work if the two printers were different.
    2013-03-17T20:23:03+00:00
    Thanks! Worked like a charm.
    2013-03-29T18:50:44+00:00
    This thread is awesome!  I didn't find an exact answer to my problem written here, but it inspired me to find the answer on my own.  For years, my HP Photosmart C795 printer has been creating a ghost printer of itself on our laptop.  It gets so confusing never knowing which printer is the online one.  I just purchased a brand new laptop, and ALREADY a ghost appeared.  Naturally, I hadn't even noticed 2 printers had installed on the brand new laptop.  S, of course, I printed to the wrong one.  I tried to switch the document to the other one, but to no avail... until I saw this thread.  The message about looking at the printer port was a stroke of genius!  I simply switched both printers to the same port and suddenly, I have 1 printer again, and my document printed!  So, thank you very much!!
    2013-05-06T16:34:12+00:00
    1. Open Printers and Faxes.
    2. Double-click the printer that holds the document(s) you want to redirect.
    3. On the Printer menu, click Properties.
    4. Click the Ports tab, and then do one of the following:
    To send documents to another printer on the same print server
    - Click the port to which the other printer is assigned and then click **OK**.
    To send documents to a printer on a different print server
    The printer must already exist and be shared on the print server.
    - Click **Add Port**, click **Local Port**, and then click
    New Port. Type the name of the other print server and the share name of the shared printer in the following format:
    **\other_print_server**share_name
    Thank you....worked well!
