Move or copy a print job to another printer
2009-04-02T03:30:57+00:00
Is it possible to move or copy a print job to another printer?  My problem is I printer a few documents from the web to a printer that was offline (not plugged into my USB port).  Is it possible to move or copy those print jobs to another printer I have on my system?
2009-04-02T10:49:39+00:00
Hello mjpalm,
Typically if you reconnect the printer, the print job will still be in the spooler for that device. If when you reconnect the printer the job does not print automatically you go into the print properties for that printer, right click on the print job and click restart.
At this time there is no function to grab print jobs from one print queue and place them in another print queue.
Judd
Microsoft Answers Support Engineer Visit our Microsoft Answers Feedback Forum and let us know what you think.
41 additional answers
    2015-05-07T09:30:45+00:00
    I haven't found a way to directly do it.  However, I found a work around that worked for me in my situation.
    I went to print queue, go to Printer, then Properties, then Ports tab... I temporarily changed the port to point to the IP address of another printer (by changing the check box).  After the queue printed, I just put the IP/port back.
    My two printers were of the same type, so I don't know if this would work with dissimilar printers.
    Daniel
    Excellent! Worked like a charm.
    Henrik E.
    2016-01-24T19:09:26+00:00
    I was just about to ask the same question....this would be awesome to move items from one printer to another.  I am fairly mobile for my work and I use several printers so the issue of printing to incorrect printer happens often enough and it would be a great feature to cut and paste into different printer queue.
    2016-02-17T17:54:51+00:00
    You just saved  my day!!!
    2016-12-05T15:40:43+00:00
    Daniel
    Life saver! It works
