How to install Teredo Tunneling Pseudo-Interface
2010-03-09T05:19:10+00:00
Dummy me... In Device Manager I uninstalled the Teredo Tunneling Pseudo-Interface. I need to know how to reinstall this interface. I've seen other postings on the web on how to configure it, but all those assume the interace is still visible in Device Manager.
So where do I find procedure to install this?
I'm on Windows 7 Professional x64.
2010-03-09T22:57:53+00:00
Hi DocBrown,
Follow the steps mentioned below:
First, let’s temporarily disable antivirus softwareand Firewallon the computer as a test.
Note: Make sure you turn-on the antivirus software and Windows Firewall later.
Now, let’s verify the status of relevant services required.
  1. Click Start , type services.msc in Start search box and hit Enter.
  2. Right-click the Peer Networking Grouping service and select Properties .
  3. Check if the service is started; if not, right-click and select Start .
  4. You may also set the Startup type to Automatic under Properties .
  5. Click OK .
Repeat the above steps for the service PNRP Machine Name Publication Service , **** too.
Next step would be to modify IPv6 registry key to enable IPV6:
ImportantThis section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
How to back up and restore the registry in Windows
http://support.microsoft.com/kb/322756/
  1. Click Start , type regedit in Start Search Bar and hit Enter.
**Note:**If you are prompted for an administrator password or confirmation, type your password or click Continue.
  1. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\TCPIP6\Parameters
  1. Check whether DisabledComponents registry key exists. If yes, let's proceed to the next step.
  2. Double click the DisabledComponents registry key and modify the value to 0 .
If the DisabledComponents entry is unavailable, you must create it. To do this, follow these steps:
  1. In the Edit menu, point to New , and then click DWORD (32-bit) Value .
  2. Type DisabledComponents , and then press ENTER.
  3. Double-click DisabledComponents .
Type 0 to enable all IPv6 components.
  1. Exit Registry Editor, and then restart the computer.
Refer:
How to disable certain Internet Protocol version 6 (IPv6) components in Windows Vista, Windows 7 and Windows Server 2008
http://support.microsoft.com/kb/929852
Hope this helps.
Gokul - Microsoft Support
[If this post was helpful, please click the "Vote as Helpful" (green triangle) button. If it helps in resolving your issue, click "Propose As Answer" or "Mark as Answer" button. By proposing/marking a post as Answered, or Helpful you help others find the answer faster.]
2010-03-11T08:44:12+00:00
Have you enabled the option - show hidden devices ?
Device Manager > View > CHECK show hidden devices.
Expand Network adapters
Is Microsoft Teredo Tunneling Adapter listed?
Cheers!
'Tis all a chequer board of nights and days,
Where destiny with men for pieces plays;
Hither and thither, and mates, and slays.
In a world without walls and fences, who needs Windows and Gates?! Life sucks! Get used to it!
52 additional answers
    2014-11-24T05:08:45+00:00
    wow. but I did open the hidden devices and expanded the network adapters and thee teredo thing is just not there anymore.
    I had gone to device mgr to uninstall it and now I can only access the internet by ethernet!
    help pleease.
    2014-12-22T19:08:42+00:00
    Thanks a bunch Gokul.
    Usually Windows answers and help are misleading but this one is right on spot and deserves many Kudos!!!
    2015-04-23T17:39:06+00:00
    I found your advice on the Teredo Tunneling Pseudo Interface and I hope you can help me.  I have been on several calls and remote access with Microsoft trying to resolve problems.  One tech while attempting to uninstall Microsoft Office 2013 did something that caused several other problems and both my Teredo and my Multimedia Audio to stop working but I did not realize this until after I hung up with him.  In control panel both programs had exclamation marks beside them and I had several flags in the action center.  I called back and that tech was able to fix the flags but not the Teredo or audio, he said I had to contact the manufacturer HP.  My computer is old and was rebuilt by a person which I no longer have been able to contact and HP told me that they no longer supply support for my model.  So I called Microsoft again and this tech had me uninstall both programs but when he went to reinstall them he could not and he again told me sorry but HP would have to fix it.  All this  was caused by your support techs and now I do not have either and no sound on my speakers.  Neither is listed in control panel at all.  If you can help please my email is ******@yahoo.com .  I hope you can help me.
