How to install Teredo Tunneling Pseudo-Interface
2010-03-09T05:19:10+00:00
Dummy me... In Device Manager I uninstalled the Teredo Tunneling Pseudo-Interface. I need to know how to reinstall this interface. I've seen other postings on the web on how to configure it, but all those assume the interace is still visible in Device Manager.
So where do I find procedure to install this?
I'm on Windows 7 Professional x64.
2010-03-09T22:57:53+00:00
Hi DocBrown,
Follow the steps mentioned below:
First, let’s temporarily disable antivirus softwareand Firewallon the computer as a test.
Note: Make sure you turn-on the antivirus software and Windows Firewall later.
Now, let’s verify the status of relevant services required.
  1. Click Start , type services.msc in Start search box and hit Enter.
  2. Right-click the Peer Networking Grouping service and select Properties .
  3. Check if the service is started; if not, right-click and select Start .
  4. You may also set the Startup type to Automatic under Properties .
  5. Click OK .
Repeat the above steps for the service PNRP Machine Name Publication Service , **** too.
Next step would be to modify IPv6 registry key to enable IPV6:
ImportantThis section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
How to back up and restore the registry in Windows
http://support.microsoft.com/kb/322756/
  1. Click Start , type regedit in Start Search Bar and hit Enter.
**Note:**If you are prompted for an administrator password or confirmation, type your password or click Continue.
  1. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\TCPIP6\Parameters
  1. Check whether DisabledComponents registry key exists. If yes, let's proceed to the next step.
  2. Double click the DisabledComponents registry key and modify the value to 0 .
If the DisabledComponents entry is unavailable, you must create it. To do this, follow these steps:
  1. In the Edit menu, point to New , and then click DWORD (32-bit) Value .
  2. Type DisabledComponents , and then press ENTER.
  3. Double-click DisabledComponents .
Type 0 to enable all IPv6 components.
  1. Exit Registry Editor, and then restart the computer.
Refer:
How to disable certain Internet Protocol version 6 (IPv6) components in Windows Vista, Windows 7 and Windows Server 2008
http://support.microsoft.com/kb/929852
Hope this helps.
Gokul - Microsoft Support
[If this post was helpful, please click the "Vote as Helpful" (green triangle) button. If it helps in resolving your issue, click "Propose As Answer" or "Mark as Answer" button. By proposing/marking a post as Answered, or Helpful you help others find the answer faster.]
2010-03-11T08:44:12+00:00
Have you enabled the option - show hidden devices ?
Device Manager > View > CHECK show hidden devices.
Expand Network adapters
Is Microsoft Teredo Tunneling Adapter listed?
Cheers!
'Tis all a chequer board of nights and days,
Where destiny with men for pieces plays;
Hither and thither, and mates, and slays.
In a world without walls and fences, who needs Windows and Gates?! Life sucks! Get used to it!
52 additional answers
    2014-08-19T06:48:46+00:00
    Thank you for your response.
    Did you try using other suggestions provided in the previous posts?
    If it does not help, then please refer to suggestions provided in this link:
    http://social.technet.microsoft.com/Forums/windows/en-US/71420f20-4006-4744-b7f7-b33e0ec2f472/teredo-tunneling-pseudointerface?forum=w7itprohardware
    I hope this information helps.
    Thank you
    2014-09-28T03:12:30+00:00
    Hi DocBrown,
    5. Click OK .
    Repeat the above steps for the service PNRP Machine Name Publication Service ,****too.
    Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
    Note: If you are prompted for an administrator password or confirmation, type your password or click Continue.
    Refer:
    Hope this helps.
    Hi Gokul
    yes this was very helpful even though I don;t see a green triangle button to press
        Martin
    2014-10-23T18:46:15+00:00
    teredo tunneling pseudo-interface
