Teredo Tunneling Pseudo-Interface This device cannot start. (Code 10)
2010-03-26T19:13:02+00:00
I have a yellow ? in my Device Manager entry for the Teredo Tunneling Pseudo-Interface. This is a 3 week old Windows 7 64bit machine. I saw messages similar to this in this forum and have run an ipconfig /all with the following results:
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Windows\system32>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : KandE-PC
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : domain.actdsltmp
Ethernet adapter Local Area Connection:
   Connection-specific DNS Suffix  . : domain.actdsltmp
   Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
   Physical Address. . . . . . . . . : 44-87-FC-40-76-6F
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   IPv4 Address. . . . . . . . . . . : 192.168.0.2(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Tuesday, March 23, 2010 8:31:13 AM
   Lease Expires . . . . . . . . . . : Saturday, March 27, 2010 1:07:41 PM
   Default Gateway . . . . . . . . . : 192.168.0.1
   DHCP Server . . . . . . . . . . . : 192.168.0.1
   DNS Servers . . . . . . . . . . . : 192.168.0.1
                                       205.171.3.25
   NetBIOS over Tcpip. . . . . . . . : Enabled
______________________end of ipconfig data____________________
I would be most appreciative if you can help me with this (apparently) slight problem. I do not know that this situation is causing me any difficulty but I like to keep my computer running well.
Thanks in advance,
Chuck
2010-03-27T14:40:05+00:00
First lets follow these below steps and  check if the issue gets resolved.
Right click the Teredo Tunneling Pseudo-Interface > Update Driver Software... > Browse my computer for driver software > Let me pick from a list of device drivers on my computer ->  network Adapter > Microsoft > Microsoft teredo tunneling adapter
To troubleshoot your issue you may try the below methods one by one.
The error message you posted indicates that you have an incompatible driver or the device driver is missing.
To make sure that you download the correct and the most up-to-date version of the driver driver, visit the Motherboard manufacturer’s website wherein all the drivers will be listed. Select the appropriate driver for the device that is compatible with Windows 7.
You may uninstall the existing driver from device manager before installing the new one.
1.    Open Device Manager by clicking the Start button, clicking Control Panel , clicking System and Maintenance, and then clicking Device Manager.
 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
2.    Locate the sound card, right click on it and select properties .
3.    Go to driver tab and click on Uninstall button to uninstall the driver associated with the device.
Once the uninstall completes, restart your computer and check if the issue got resolved.
Thanks and Regards:
I. Suuresh Kumar- Microsoft Support.
190 additional answers
    2017-01-31T10:39:03+00:00
    Go to start menu and in the search bar type in REGEDIT to open the registry editor.
    Navigate through the following:
    HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\SERVICES\TCPIP6\PARAMETERS.  In the right pane, right click Disabled Components and select edit.  Set the DWord value to 0."
    Restart your computer.
