Devices and Printers Dialog Box Empty
2009-10-30T22:04:54+00:00
When I open my "Devices and Printers" dialog box, it is empty; nothing shows up and the item listing says "0 items".
The devices and printers showed up in the Devices and Printers dialog box earlier, but now are gone from the dialog box.  However, they are still in the system as everything seems to work.  The problem comes with trying to set the preferences for any of the devices or printers since they can't be seen or accessed.
Anyone got any ideas of how to get the devices and printers to show up again?
2010-03-07T06:22:04+00:00
Devices and printers will show one device when you have configured multiple printers for the same device.   There is a fly out menu to get to all the other printers on the device.    Use the spooler teams UI, printmanagement.msc to view all local printers on Pro and Ultimate.
The old printers folder can be launched if you are running Home versions.
Open a command prompt and paste this in.
start shell:::{26EE0668-A00A-44D7-9371-BEB064C98683}\0::{2227A280-3AEA-1069-A2DE-08002B30309D}
Alan Morris Windows Printing Team; Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/Default.aspx?adv=1
2009-11-27T18:23:06+00:00
I am having the same problem. I did a clean install from Vista and the computer has worked fine for weeks.  Today, my devices and printer window is empty. I can still print from some applications, but Windows Live Mail gives me an error when I select print:
'an error has occurred in the script on this page'
line:291
char: 1
error: interface not registered
Code: 0
URL: res://ieframe.dll/preview.js
Do you want to continue running scripts on this page - Yes or No?
Barry
By the way, no new hardware has been installed recently.
I found another post that solved my problem.  I was about to give up and re-install Windows 7, but tried this and it worked.
Go to: http://iefaq.info/index.php?action=artikel&cat=42&id=133&artlang=en
for the CMD file and explanation.
142 additional answers
    2011-02-17T19:50:28+00:00
    @PauloMiranda
    I tried that, tried bluetooth, tried print spooler...I tried everything what is written here. :(
    I don't have McAffee, I use KIS. When I disable KIS result is the same.
    I can see printer in Device manager - Properties, it says "this device is working properly"
    I can see it with "printmanagement.msc",
    I can see it with "start shell:::{26EE0668-A00A-44D7-9371-BEB064C98683}\0::{2227A280-3AEA-1069-A2DE-08002B30309D}"
    But, "control panel - view devices and printers" does not work. Green line can't load till the end. When I double click on View devices...it opens, but it is empty folder.
    That is the problem.
    2011-02-18T01:07:49+00:00
    Okay.  Thanks.  I'm just a printer guy, although the delay you reference sounds exactly like the McAffee issue. If you ever get the computer to show up check for the printer there.  If the printer is available in Print Management use this UI to perform the admin tasks, that is the function of the feature.  http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01911895&cc=us&lc=en&dlc=en&product=3737195
    2011-02-23T04:32:24+00:00
    None of the solutions offered so far worked for me. SP1 doesn't fix it either. :-(
    However, this did:
    • Boot up in safe mode
    • Open Devices & Printers (note: stuff shows up!)
    • Right click on the window and select: View=large icon
    Sort by = name/ascending
    Group by = classification/ascending
    (this was the default for me; I didn't need to change anything.)
    • exit & reboot. Let it come up normally.
    Now, how permanent this is, I have no idea. But at least it worked once!
